[ROM][CM9][Nightly][Unofficial]
Uscita da pochi giorni per il nostro tab una versione della cm9, la sto provando da alcuni giorni sicuramente molto piu fluida e veloce della stock .
Guida:
Da chi proviene da altre rom:
Download to your external SD card
Reboot into recovery
Backup current installation
Wipe data, system, cache, dalvik cache (optional use my Blackhole scripts)
Install from zip, pick the CM9 zip
Flash gapps
Once done, wipe cache and dalvik cache again
Reboot system
Wait 10 minutes, then reboot system
Log into google and setup your device
Enjoy
Bugs:
Current known Bugs
6-11-12, B1: You have to disable the screen off animation or your device will reset everytime you press the power button. Settings>Display> Uncheck Screen-off animation prevents it.
6-12-12, B1: Labros1995 reports rotation lock still broken.
6-16-12, NA: HDMI audio still not working, reported by pomka78
ROM
Gapps
