http://localhostr.com/file/EG7nEvx/taboonay.png
http://localhostr.com/file/ZPeXsGG/1..._add_16x16.gif Changelog from stock (Based on
Acer_A500_7.006.01_COM_GEN1 &
Acer_A501_4.027.15_COM_GEN1 for A501 support) :
Rooted
Deodexed
Busybox, Bash, Nano...
CPU Freq & governor based on screenstate.
optipng'ed & zipaligned apps to reduce size & memory usage
sysro, sysrw
Insecure boot
Removed some Acer apps
Kernel tweaks
Optimized lowmemkiller settings
Mount (ext4) tweaks
Modded host file for ads filter
Added PolarisOffice (from Asus)
NTFS support (with Driver Mount)
HFS support (with custom kernel)
Dalvik optimized
Internet tweaks
DRM Service disable
Optimized Acer wallpaper from Launcher2 (reduce size)
Updated Apps
Added ES File Explorer
Motorola Bootanim
WiFi Channel 12-13 and Ad-Hoc support (Thx to richardtrip)
Google Music updated to 3.0.2
Asus Weather widget
Samsung Dual Clock widget
Now including TabooTools (custom app)
http://localhostr.com/file/TM3sbyU/1...rash_16x16.gif Removed :
Acer About, AcerClockWidget, AcerNidus, AcerOneTimeInit, Acer Registration, Acer Sync, Acer Sync Helper, ApInAp, DocsToGo, Hero Of Sparta, Lets Golf, LumiRead, NFS, TegraZone, TopGames, Zinio
Online Kitchen (apps/games/bootanim...and more)
Screenshots :
http://shoobee.eu/upp/thumbs/993567home.png http://shoobee.eu/upp/thumbs/440207settings.png
http://shoobee.eu/upp/thumbs/905202tbt.png http://shoobee.eu/upp/thumbs/364629tbt2.png
Setup 3G dongle for A500
INSTALLAZIONE (
con permessi di root) e Acer Recovery Installer
- Scaricate dal Market l'app "Acer Recovery Installer"
- Avviate l'app e concedete i permessi di root
- Installare la ClockWorkMod Recovery 1.3.4 di thor2002ro (fate un backup dell'originale)
- Fate un Backup della rom attuale (l'originale; questo per poter tornare indietro in qualsiasi momento)
- Andare in Download/Install ROMs e scaricare Tabooney 1.1 e 2.0
- Installate prima Tabooney 1.1 (eseguite i Wipe)
- Installate Tabooney 2.0 (eseguite i Wipe)
In alternativa potete scaricare i file (dopo aver installato la CWM) direttamente da qui:
Tabooney 1.1
Tabooney 2.0
Tabooney 2.1
Tabooney 2.1b
Tabooney 2.2 update per 2.1 e 2.1b
Copiare i file nella MicroSD ed avviare la CWM (Tasto Power + Tasto Volume vicino al power)
- Selezionare "Install zip from SD card"
- Selezionare il file precedentemente copiato nella micro SD
- Cliccare su "Yes"
- Attendere il flash
- Selezionare Reboot
- Godetevi la nuova ROM.
OVERCLOCK:
E' possibile con questa ROM ed un kernel apposito eseguire l'OC e l'UV.
Io lo utilizzo a 1400Mhz.
Il Kernel va flashato da CWM come la ROM copiando il file nella microSD:
[KERNEL] Stock/HV/Taboonay V3.0 for HC 3.2 24-08 - 1.64Ghz/UV control
[KERNEL] Stock/HV/Taboonay V3.7 for HC 3.2 16-10 - 1.64Ghz/UV control < ATTENZIONE POSSESSORI A501 : Questo Kernel freeza in 3G
CARATTERISTICHE KERNEL:
- Voltage control (use setcpu or "pimp my cpu" for controlling uv).
- Update to 2.6.36.4
- OC to 1.64Ghz (use 1.5Ghz on daily basis, 1.6 and 1.64 not stable on all tablets)
- memcpy performance patch (14% increase)
- Updated wifi driver
- Update video drivers
- BFQ
- automated per session task groups
- TUN
- CIFS
- NTFS (Write support)
- UTF8
- NFS
- USB_WWAN
- OPTION
- HFS
Update kernel:
Added features:
- Voltage control (use setcpu/ "pimp my cpu" or System Tuner for controlling uv).
- BFQ
Enabled modules:
- TUN
- CIFS
- UTF8
- NFS
- USB_WWAN
- OPTION
- HFS
RINGRAZIAMENTI:
Kernel: richardtrip (XDA:
[KERNEL] Stock/HV/Taboonay V3.0 for HC 3.2 24-08 - 1.64Ghz/UV control - xda-developers)
ROM: vache (XDA:
[ROM][HC3.2] Taboonay 2.0 (24/08/2011) - xda-developers)
