codice:
./makeMtk -t jrdhz72_we_vf_jb3 bootimage
mediatek/build/custgen.mk:6: attenzione: sovrascrittura dei comandi per l'obiettivo "mediatek/custom/out/jrdhz72_we_vf_jb3/kernel/accelerometer/cust_acc.c"
mediatek/build/custgen.mk:6: attenzione: comandi obsoleti per l'obiettivo "mediatek/custom/out/jrdhz72_we_vf_jb3/kernel/accelerometer/cust_acc.c" ignorati
2015/09/21 01:30:59 custgening...
LOG: out/target/product/jrdhz72_we_vf_jb3_custgen.log
done
==> [OK] 2015/09/21 01:31:28
2015/09/21 01:31:28 sign-modeming ...
LOG: out/target/product/jrdhz72_we_vf_jb3_sign-modem.log
[Dependency] /home/hp/Immagini/VF785/mediatek/build/tools/sign_modem.pl
[Dependency] /home/hp/Immagini/VF785/mediatek/build/tools/pack_dep_gen.pm
CHECK PARAMETER
parameter check pass (2 MDs)
MTK_SEC_MODEM_AUTH = no
MTK_SEC_MODEM_ENCODE = no
modem_cipher = yes
PROCESS MODEM IMAGE (mediatek/custom/out/jrdhz72_we_vf_jb3/modem/modem_1_wg_n.img)
[Dependency] /home/hp/Immagini/VF785/mediatek/custom/common/secro/SECRO_DEFAULT_LOCK_CFG.ini
doesn't execute Cipher Tool and Sign Tool ...
Fill AC_REGION
[Dependency] /home/hp/Immagini/VF785/mediatek/build/tools/SecRo/secro_post.pl
[Dependency] /home/hp/Immagini/VF785/mediatek/custom/common/secro/AND_SECURE_RO
[Dependency] /home/hp/Immagini/VF785/mediatek/custom/jrdhz72_we_vf_jb3/secro/AC_REGION
*********************** SETTINGS *********************
Project = jrdhz72_we_vf_jb3
Custom Dir = jrdhz72_we_vf_jb3
MTK_ENABLE_MD1 = yes
MTK_ENABLE_MD2 = no
MTK_PLATFORM = MT6572
ac_region = mediatek/custom/jrdhz72_we_vf_jb3/secro/AC_REGION
does not has AP specific AC_REGION_RO image, use common AC_REGION_RO
and_secro = mediatek/custom/common/secro/AND_SECURE_RO
does not has MODEM specific SECURE_RO image, use common SECURE_RO
md_secro = mediatek/custom/common/secro/SECURE_RO
does not has MODEM specific SECURE_RO image, use common SECURE_RO_sys2
md2_secro = mediatek/custom/common/secro/SECURE_RO_sys2
MTK_SEC_SECRO_AC_SUPPORT = no
PROCESS SECFL.ini
[Dependency] /home/hp/Immagini/VF785/mediatek/build/tools/sign_sec_file_list.pl
*** Sign ANDROID Secure File List ***
file doesn't exist
*** Sign SECRO Secure File List ***
remove old file list (1) ...
remove old file list (2) ...
[Dependency] /home/hp/Immagini/VF785/mediatek/custom/jrdhz72_we_vf_jb3/security/image_auth/IMG_AUTH_KEY.ini
[Dependency] /home/hp/Immagini/VF785/mediatek/custom/jrdhz72_we_vf_jb3/security/sec_file_list/SFL_CFG.ini
[Dependency] /home/hp/Immagini/VF785/mediatek/custom/jrdhz72_we_vf_jb3/security/sec_file_list/SECRO_SFL.ini
[Dependency] ./mediatek/build/tools/SignTool/SignTool.sh
[Dependency] /home/hp/Immagini/VF785/mediatek/build/tools/SignTool/Makefile /home/hp/Immagini/VF785/mediatek/build/tools/SignTool/../../../../mediatek/config/out/jrdhz72_we_vf_jb3/ProjectConfig.mk /home/hp/Immagini/VF785/mediatek/build/tools/SignTool/auth/Makefile
ar rcs lib/SignLib.a obj/lib_sign.o obj/sign_util.o
gcc -m32 -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 obj/main.o obj/sec_auth.o auth/ToolLib.a lib/SignLib.a -o SignTool_MTK
[Dependency] /home/hp/Immagini/VF785/mediatek/build/tools/SignTool/auth/ToolLib.a
ln -s SignTool_MTK SignTool
[SignTool] NAND page size not supported, set to default 2048!!
[Android SignTool v3.1 (FB)]
Built at dom 20 set 2015, 21.22.45, CEST
[SignTool] sign image (normal)...
[SignLib] import CUSTOM_RSA_N
[SignLib] import CUSTOM_RSA_D
[SignLib] import CUSTOM_RSA_E
[AUTHEN] rsa.N length = 1024 bytes
[AUTHEN] rsa.E length = 20 bytes
[SignLib] empty customer name 'NULL'
[SignLib] VERIFY_COUNT=1
[SignLib] VERIFY_OFFSET[0]=0
[SignLib] VERIFY_LENGTH[0]=0
[SignLib] CHUNK_SIZE=0
[SignUtil] sec_hdr->img_len = 26
[SignUtil] Chunk size is 0, truncate verify count to 1(v3)
[SignUtil] The sign length is zero, and sign offset is : 0 (0x0)
[SignUtil] Set the sign length to rest whole image length : 26 (0x1a)
[0] min_pos is 0
p_ext_cfg->verify_offset[0] is 0
[0] region_end is 26
[0] next region start is 26
[SignUtil] Sign region (0->25) ok(v3)
[SignLib] hdr.magic_num = 0x53535353
[SignLib] hdr.cust_name =
[SignLib] hdr.img_ver = 1 (0x1)
[SignLib] hdr.img_len = 26 (0x1a)
[SignLib] hdr.img_off = 64 (0x40)
[SignLib] hdr.s_off = 2054781561 (0x7a797a79)
[SignLib] hdr.s_len = 2054781561 (0x7a797a79)
[SignLib] hdr.sig_off = 90 (0x5a)
[SignLib] hdr.sig_len = 148 (0x94)
[AUTHEN] RSA padding : RAW
[AUTHEN] sign image ... pass
[AUTHEN] output signature:
0x55,0x53,0x43,0xbc,0x8d,0x0c,0x96,0xbb,0x2c,0xa4,0x72,0x89,0x9f,0x0d,0x2d,0x7b,0xd7,0x21,0x3b,0xe7,0x9a,0x95,0x4e,0x11,0x79,0x7e,0xf8,0x66,0x58,0x88,0xd6,0x73,0x07,0xcd,0xbc,0xa5,0xb4,0x75,0x59,0x15,0x99,0x3b,0xd8,0x05,0x55,0xcf,0x62,0xfa,0x5c,0xd9,0x76,0x67,0x17,0x54,0x75,0x3e,0x1c,0x4d,0x13,0x60,0x81,0x02,0x60,0x4e,0xaf,0xdd,0xeb,0xad,0x16,0x2e,0x74,0x03,0xde,0xe0,0x1b,0x9e,0x11,0x07,0xff,0xc8,0x04,0x11,0x22,0x1e,0x16,0x40,0x89,0x82,0x68,0x13,0xf7,0x2e,0x10,0x98,0xdf,0xf3,0x4d,0x40,0x2c,0x40,0x61,0xc1,0xb1,0xd8,0x0b,0x1d,0x60,0x79,0xec,0xb5,0xd2,0x6e,0x8a,0x43,0x09,0x75,0x29,0xf2,0x52,0xb7,0x33,0xb6,0x01,0x02,0x7b,0x97,0x52,0x45
[AUTHEN] verify signature... pass
[SignLib] Hash value :
0xe8,0xf7,0x4b,0x32,0x0,0x5c,0xa,0x89,0xbe,0xa0,0xc7,0x7b,0xed,0x36,0x94,0x11,0x6f,0x6b,0x78,0x87,
SIGN PASS !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!(Normal IMG)
==> [OK] 2015/09/21 01:31:30
2015/09/21 01:31:30 gen out/target/product/jrdhz72_we_vf_jb3/obj/include/dfo/CFG_Dfo_File.h ...
No need update file: out/target/product/jrdhz72_we_vf_jb3/obj/include/dfo/CFG_Dfo_File.h
==> [OK] 2015/09/21 01:31:31
2015/09/21 01:31:31 gen out/target/product/jrdhz72_we_vf_jb3/obj/include/dfo/CFG_Dfo_Default.h ...
No need update file: out/target/product/jrdhz72_we_vf_jb3/obj/include/dfo/CFG_Dfo_Default.h
2015/09/21 01:31:31 gen out/target/product/jrdhz72_we_vf_jb3/obj/include/dfo/DfoDefines.h ...
No need update file: out/target/product/jrdhz72_we_vf_jb3/obj/include/dfo/DfoDefines.h
2015/09/21 01:31:32 gen out/target/product/jrdhz72_we_vf_jb3/obj/include/dfo/DfoBoot.h ...
No need update file: out/target/product/jrdhz72_we_vf_jb3/obj/include/dfo/DfoBoot.h
==> [OK] 2015/09/21 01:31:32
2015/09/21 01:31:32 gen out/target/product/jrdhz72_we_vf_jb3/obj/include/dfo/DfoBootDefault.h ...
==> [FAIL] 2015/09/21 01:31:33
make[1]: *** [out/target/product/jrdhz72_we_vf_jb3/obj/include/dfo/DfoBootDefault.h] Errore 1
make: *** [bootimage] Errore 2
ottengo lo stesso errore con recoveryimage cacheimage.
