Ho richiesto qui Contattaci | Brondi il firmware originale e loro mi hanno risposto con un'email contenente il link
Posso chiederti i dati (build, kernel etc..) dell' Android installato sul tuo Caesar, e soprattutto la Data del software? THNX!
-EDIT-
Questo è il Build.prop che ho estratto dall'Aggiornamento che hai postato te:
# begin build properties
# autogenerated by buildinfo.sh
ro.sw.version=Caesar-I95H-Italy-QB18D-T600-6589V1.0.0
ro.sw.version.incremental=B06T02
ro.custom.btname = Caesar
ro.build.id=JOP40D
ro.build.display.id=Caesar-I95H-Italy-QB18D-T600-6589V1.0.6
ro.build.version.incremental=eng.builder59.1387527 396
ro.custom.build.version=1387527396
ro.build.version.sdk=17
ro.build.version.codename=REL
ro.build.version.release=4.2.1
ro.build.date=Fri Dec 20 16:17:56 CST 2013
ro.build.date.utc=1387527476
ro.build.type=user
ro.build.user=builder59
ro.build.host=eastaeon-desktop
ro.build.tags=test-keys
ro.product.model=Caesar
ro.product.brand=BRONDI
ro.product.name=Caesar
ro.product.device=BRONDI
ro.product.board=Caesar
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=BRONDI
ro.product.locale.language=it
ro.product.locale.region=IT
ro.wifi.channels=
ro.board.platform=
# ro.build.product is obsolete; use ro.product.device
ro.build.product=BRONDI
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=BRONDI-user 4.2.1 JOP40D eng.builder59.1387527396 test-keys
ro.build.fingerprint=BRONDI/BRONDI/BRONDI:4.2.1/JOP40D/1387527396:user/test-keys
ro.build.flavor=
ro.build.characteristics=default
ro.oau.product.manufacturer=BRONDI
ro.oau.product.device=Caesar
ro.oau.product.locale.language=it
ro.oau.build.display.id=Caesar-I95H-Italy-QB18D-T600-6589V1.0.6
ro.oau.operator.optr=cu
# end build properties
# begin mediatek build properties
ro.mediatek.version.release=Caesar-I95H-Italy-QB18D-T600-6589V1.0.6
ro.mediatek.platform=MT6589
ro.mediatek.chip_ver=S01
ro.mediatek.version.branch=ALPS.JB2.MP
ro.mediatek.version.sdk=1
# end mediatek build properties
# system.prop for generic sdk
rild.libpath=/system/lib/mtk-ril.so
rild.libargs=-d /dev/ttyC0
# MTK, Infinity, 20090720 {
wifi.interface=wlan0
# MTK, Infinity, 20090720 }
# MTK, mtk03034, 20101210 {
ro.mediatek.wlan.wsc=1
# MTK, mtk03034 20101210}
# MTK, mtk03034, 20110318 {
ro.mediatek.wlan.p2p=1
# MTK, mtk03034 20110318}
# MTK, mtk03034, 20101213 {
mediatek.wlan.ctia=0
# MTK, mtk03034 20101213}
wifi.tethering.interface=ap0
ro.opengles.version=131072
wifi.direct.interface=p2p0
dalvik.vm.heapgrowthlimit=128m
dalvik.vm.heapsize=256m
# USB MTP WHQL
ro.sys.usb.mtp.whql.enable=0
# Power off opt in IPO
sys.ipo.pwrdncap=2
ro.sys.usb.storage.type=mtp,mass_storage
# USB BICR function
ro.sys.usb.bicr=yes
# USB Charge only function
ro.sys.usb.charging.only=yes
# audio
ro.camera.sound.forced=0
ro.audio.silent=0
ro.zygote.preload.enable=0
persist.sys.timezone=Europe/Brussels
# ADDITIONAL_BUILD_PROPERTIES
ril.specific.sm_cause=0
gps.solution.combo.chip=1
ril.external.md=0
fmradio.driver.chip=3
ro.sf.hwrotation=0
ril.current.share_modem=2
launcherplus.allappsgrid=2d
launcher2.allappsgrid=3d_20
curlockscreen=1
ro.mediatek.gemini_support=true
ro.gemini.smart_3g_switch=1
persist.radio.fd.counter=15
persist.radio.fd.off.counter=5
persist.radio.fd.r8.counter=15
persist.radio.fd.off.r8.counter=5
persist.mtk.wcn.combo.chipid=-1
drm.service.enabled=true
fmradio.driver.enable=1
ril.first.md=1
ril.flightmode.poweroffMD=1
ril.telephony.mode=1
ril.radiooff.poweroffMD=0
dalvik.vm.mtk-stack-trace-file=/data/anr/mtk_traces.txt
mediatek.wlan.chip=MT6628
mediatek.wlan.module.postfix=_mt6628
ro.config.notification_sound=Adara.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
ro.config.ringtone=BirdLoop.ogg
ro.setupwizard.mode=OPTIONAL
ro.com.google.gmsversion=4.2_r1
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
E' simile a quello che hai sul tuo??
Ultima modifica di ilnikko; 04-07-14 alle 16:55
Questo è il mio
ro.build.id=JOP40D
ro.build.display.id=Caesar-I95H-Italy-QB18D-T600-6589V1.0.4
ro.build.version.incremental=eng.builder32.1376286 814
ro.custom.build.version=1376286814
ro.build.date=Mon Aug 12 13:55:30 CST 2013
ro.build.date.utc=1376286930
ro.build.type=user
ro.build.user=builder32
ro.wifi.channels=
ro.board.platform=
ro.build.description=BRONDI-user 4.2.1 JOP40D eng.builder32.1376286814 test-keys
ro.build.fingerprint=BRONDI/BRONDI/BRONDI:4.2.1/JOP40D/1376286814:user/test-keys
ro.build.flavor=
ro.oau.build.display.id=Caesar-I95H-Italy-QB18D-T600-6589V1.0.4
ro.mediatek.version.release=Caesar-I95H-Italy-QB18D-T600-6589V1.0.4
# USB MTP WHQL
sys.ipo.pwrdncap=2
# USB BICR function
ro.sys.usb.bicr=yes
# audio
ro.audio.silent=0
ril.external.md=0
ro.sf.hwrotation=0
curlockscreen=1
ril.first.md=1
net.bt.name=Android
-EDIT-
qui si possono vedere le differenze (a sinistra il mio e a destra "l'update")
http://www.mergely.com/FdXDBI64/
Ultima modifica di fabrixz; 04-07-14 alle 18:12
Sì, è esattamente uguale al mio...
Ora, le "differenze" alla fine dei conti mi sembrano così infime che ritengo quantomeno assurdo provare a flashare e friggere magari tutto per uno 0.0.2 di differenza...
MMMAAHHHH!!
Si, infatti a me non importava avere un aggiornamento, ma solo la sicurezza di poter ripristinare il device poiché vorrei fare alcune modifiche e in caso non andassero bene c'è li il firmware originale
Guarda, da quello che ho letto "in giro", è più Safe farsi un Nandroid-Backup con MTK-Tools (presente qui nel Forum, con Guida acclusa...).
Questo software crea un' Immagine del TUO stato attuale della ROM e dei programmi/impostazioni, che viene salvato, volendo, anche su MicroSD (occupa un po' di spazio...). In caso di Casini, è Molto Facilmente ripristinabile riavviando il telefono in modalità Recovery, un po' come fa Windows, quando riavvia "L'ultima configurazione sicuramente funzionante"... In ogni caso è meno rischioso di flashare col Tool.
-EDIT-
Credo di aver scovato la SOLA differenza dei 2 "Build.prop", e quindi nelle ROM.
Grazie a quell' Editor Affiancato che hai postato, ho visto che, a parte i "numerini progressivi un po' più alti" in quello di Dicembre, l'unica differenza è in questa linea di settaggio, nuova, e non presente nella nostra versione:
che, leggendo in giro, serve a abilitare il 3g sullo slot 2 senza avere la sim nello slot 1.
Quindi, se non è il tuo caso, te ne freghi... Altrimenti puoi prendere 'sta linea ed incollarla con un editor di tensto NEL tuo build.prop (previo esseretene fatto un BKUP!). Riavvii ed hai la 'nuova' Feature...!!
Ultima modifica di ilnikko; 05-07-14 alle 10:20
Effettivamente per "salvare" il telefono potrei fare una copia con mtk-tools, ma per ripristinare la garanzia, devo per forza avere il firmware originale...
Sì,devi avere un FW originale, ma secondo me è meglio rifarsi alla tua versione attuale...
Non so, non mi affiderei troppo al Flash Tool, SE non Strettamente necessario... E non avendo neppure un aggiornamento ad una 4.3 - 4.4...mmmmmm...!!
Ho fatto il root con il metodo sopra ad un Brondi Caesar, ma preferisco tornare indietro perchè non ho tempo da dedicare, come si fa l' unroot?
