Utente del giorno: Varioflex con ben 2 Thanks ricevuti nelle ultime 24 ore
Rom Flexiview FV-1 Android 2.2 TV Box - Uberoid Alpha (per weweb)
    ho trovato questa rom in rete modificata da HardcoreHacker da techknow.t0xic.nl/forum
    la sto provando e va molto bene...se volete la potate scaricare da
    QUI
    Specs:
    - CORTEX A8 core, Samsung S5PV210, frequency up to 1GHz
    - 512MB RAM
    - Built-in 2G memory space
    - Android2.2 operating system
    - Built-in WiFi module, can be do a wireless network connection
    - RJ45 interface for wired network connection
    - Support 1080P video playback
    - HDMI video output, connect to Hi-definition television through the interface, and to play high-definition video
    - USBinterface for connecting high-capacity mobile hard disk
    - USBinterface for connecting a mouse and keyboard to operate the box
    - Support weather, calendar and desktop clock tool
    - Support wireless Bluetooth keyboard
    - Bluetooth File Transfer
    - Support for 2.4G wireless remote control operation
    - Support FLASH PLAYER 10.1, available online play video
    - Support for music playback, photo browsing, and enjoy more family entertainment
    - SD card expansion
    Changelog:
    added Google Play Store 3.5.15 (formerly known as the Google Market)
    added su bin
    modified build.prop to spoof a Samsung Galaxy S II
    disabled auto updates
    changed boottext
    removed facebook
    removed google maps 5.5.0
    updated youtube to 2.3.4
    removed air control lite
    removed streetview for google maps
    removed quickoffice trail
    HowTo flash:
    - Extract the OSK from the 7z
    - Copy it to a SD:\UpdateKit\ (so you will have SD:\UpdateKit\android.osk)
    NOTE: UpdateKit has a capitol "U" and capitol "K"!
    - On the FV-1 box, go to "Settings"
    - Once in "Settings", go to "Update System"
    - Confirm the next screen by pressing "Next"
    - You are asked if you would like to perform a backup, if you would like to do so press "continue", else just "skip"
    - Before starting the update, you are instructed not to disconnect the power supply or remove the memory card during the update. Press "Start" to begin the upgrade.
    - At this stage the update (android.osk) will be processed, after a while, you are prompted to restart the box, confirm with "OK".
    - The FV-1 will restart and the update will be installed, after a few minutes the green LED ready indicator flashes, the update is then complete!
    - Disconnect the power supply and remove the SD.
    - Connect the power supply, the first boot will take a few mins, then the upgrade is complete.
    Firmware originale - ufficiale lo potete scaricare da
    QUI
    personalmente sto testando quello modificato mi sembra più attivo il weweb anche il video... vedo un po megliorata la qualità...
    ps: non mi responsabilizzo de qualche danno causato a vostro dispositivo...ho postato per condividire la info se volete provate basta seguire le istruzioni...la rom non è stata fatta da me...
    saluti
    Ultima modifica di Ricky72; 30-07-12 alle 14:19
    Quote Originariamente inviato da Ricky72 Visualizza il messaggio
    QUI
    Specs:
    - 512MB RAM
    - SD card expansion
    Changelog:
    added su bin
    changed boottext
    removed facebook
    HowTo flash:
    QUI
    saluti
    CIAO la sto provando.... ma rom con gingerbread, honeycomb o ICS niente?? strano eppure è single core per honeycomb e le caratteristiche hardware per ics le ha.. bisognerebbe chiedere aiuto a qualche dev...
    Quote Originariamente inviato da alerosta Visualizza il messaggio
    poi avere più informazioni
    QUI
    anche qua
    Project Gus
    oppure
    QUI
    Ultima modifica di Ricky72; 10-08-12 alle 20:00
    ho provato a cerca ma niente android 2.3..... da come ho letto in giro bisogna fare un port dal galaxy s2 che dovrebbe avere lo stesso hardware... quindi in teoria anche ICS però il file OSK come si scompatta.... io sono su ubuntu.
    Senior Droid L'avatar di lolloandro
    Feb 2011
    Ringraziato 108 volte in 86 Posts
    Ho trovato questo forum dove parlano di rom ics 4.0.3, ecco il link, è da capire se è compatibile con il nostro Flexiview FV1,
    Ecco: Android 4.0 TV Box advice. - Android Forums
    Ricky72 guarda un po se si può usare??
    Bye.
    P.S. Vale la pena mettere sta rom Uberoid, c'è differenza dalla stock?
    Quote Originariamente inviato da lolloandro Visualizza il messaggio
    Bye.
    il firmware da te linkato è per dispositivi con CORTEX A9
    il nostro è CORTEX A8 quindi direi proprio di no!
    Feb 2011
    Ho messo questa rom, ma ho notato che ho perso il root.
    Mi sa che devo risbloccarlo con z4root....
    Mi sembra un peletto più veloce della stock.
    Sto girando come un pazzo ma non si trova nulla oltre il firmware 2.2 , peccato mi sarebbe piaciuto avere ICS sul Box...
    Grazie Ricky.
LinkBacks (?)
  1. 14-08-12, 18:12
