importazione preferiti su android....
io l'inglese lo so pochino(ho fatto francese) che ne dite di questo trovato su un forum inglese:
If you want to poke around in it, assuming you have JF's 1.3.1 modded RC30, here's how:
* open Terminal Emulator
* type: su
* type: cd /data/data/com.android.browser/
* type: cd databases (and if that fails, do an ls and see what the directory is really named, maybe database? My memory is fuzzy.)
* type: ls
* the browser db should be named browser.db or something
* type: sqlite3 <database name>
And you're in. Type .help for a list of commands, like .tables to display all tables, .schema <table name> to view the table schema, etc. You can just issue SQL commands from there to update your bookmarks, or add/delete them.
fatemi sapere....ora sono al lavoro ci risentiamo stasera...
