Allora ragazzi, credo di essere diventato imbecille....
Non riesco a fare sta cosa perchè non mi vede/monta l'ext4.
- Galaxy Y Duos GT-S6102 - v2.3.6 - S6102XXLD1 - kernel 2.6.35.7 - build GINGERBREAD.XXLD1
- Ho una sd da 16 GB (2GB per la ext4 e 14 per la fat32) e ho provato a formattarla in tutti i modi, mettendo prima la fat32 e dopo la ext4, prima la ext4 e dopo la fat32, col minitools in winzoz, con gparted in linux.
- Inoltre ogni volta prima di iniziare eseguo "wipe data/factory reset", "wipe cache partition" e "apply update from sdcar" selezionando dtapps2sd-2.7.5.3-beta04-signed.zip
codice:
$ su
# a2sd zipalign
[ ] GREP: Using ROM Busybox.
[ ] REBOOT: Using ROM Busybox.
[ ] FDISK: Using ROM Busybox.
[ ] CAT: Using ROM Busybox.
[ ] MKDIR: Using ROM Busybox.
[ ] RMDIR: Using ROM Busybox.
[ ] CHMOD: Using ROM Busybox.
[ ] MOUNT: Using ROM Busybox.
[ ] UMOUNT: Using ROM Busybox.
[ ] CP: Using ROM Busybox.
[ ] RM: Using ROM Busybox.
[ ] MV: Using ROM Busybox.
[ ] LN: Using ROM Busybox.
[ ] MORE: Using ROM Busybox.
[ ] MKNOD: Using ROM Busybox.
[ ] AWK: Using ROM Busybox.
[ ] SLEEP: Using ROM Busybox.
[ ] SYNC: Using ROM Busybox.
[ ] TEE: Using ROM Busybox.
__ _____
|__/ | Darktremor Apps2SD 2.7.5.3 Beta 4a (2011-01-30)
[-] Checkpoint 1: Check for SD Card Fix and Implement.
[-] Checkpoint 2: Run Dalvik Heap Program (if exists).
[-] Checkpoint 3: Run Set Low Memory Killer Program (if exists).
[-] Checkpoint 4: Determine Mount Point.
[-] Checkpoint 5: Set Parameter Variables.
[ ] GetProp Command = /system/bin/toolbox getprop
[ ] SetProp Command = /system/bin/toolbox setprop
[ ] Mount Point = /system/sd
[-] Checkpoint 6: Insert CyanogenMod patch.
[ ] Creating /cache/dc
[ ] Symlinking /cache/dalvik-cache to /data/dalvik-cache
[-] Checkpoint 7: Complete Dalvik Cache Move (if applicable).
[-] Checkpoint 8: Resetting Dalvik Cache Partition
[-] Checkpoint 9: Switching Davlik Cache to Cache Partition (if applicable)
[-] Checkpoint 10: Checking for existence of command parameter
[-] Checkpoint 11: Check for a2sd help command
[-] Checkpoint 12: Check for a2sd check command
[-] Checkpoint 13: Display version information.
[ ] Starting Darktremor Apps2SD Version 2.7.5.3 Beta 4a
[-] Checkpoint 14: Check for filesystem support.
[-] Checkpoint 15: Mount partition.
[-] Checkpoint 16: Reset Dalvik if Flag File is present.
[-] Checkpoint 17: Mount Swap.
[-] Checkpoint 18: Display Heap Size.
[ ] Heap Size set to: 64m
[-] Checkpoint 19: Check for start parameter and launch start2sd if needed.
[ ] Launching Apps2SD Start Program with zipalign
[X] No a2sd.swap environment variable found.
[X] Problem detected: Darktremor Apps2SD may not have ran
during boot. Cannot read a2sd.mountpoint.
[ ] Starting Darktremor Apps2SD in zipalign mode
[ ] Creating ZipAlign flag file.
[ ] Setting File System Ready property to 1.
codice:
# a2sd cachesdreset
__ _____
[ ] Launching Apps2SD Start Program with cachesdreset
[ ] Starting Darktremor Apps2SD in cachesdreset mode
[X] EXT partition is not mounted. Cannot continue.
codice:
# a2sd check
__ _____
[ ] Starting Apps2SD Check Program.
Darktremor 2.7.5.3 Beta 4a Apps2SD Status Report
Legend: []=Setting is correct
[]=Setting is correct, but not optimal.
[]=Setting is incorrect and needs to be fixed or option is not available.
Block Device - [] Not Found
- [] SD card cannot mount
Dunque mi risultano i seguenti errori:
Qualcuno ha idea di cosa possa fare?
