Utente del giorno: Stahl con ben 12 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: complicazio con ben 35 Thanks ricevuti negli ultimi sette giorni
Utente del mese: Stahl con ben 180 Thanks ricevuti nell'ultimo mese
Perché conviene flashare una radio da fastboot anziché da recovery
    Androidiano VIP L'avatar di Andreamer
    May 2010
    Italy
    iPhoneSE,i9195,P5100,I9023,G1
    Ringraziato 173 volte in 130 Posts
    Reasons to flash radio via fastboot
    First of all, you are s-off. So it's very probable you changed the hboot. When you flash a radio over a recovery, the recovery extracts the downloaded radio.zip into /cache partition. So the radio.img is stored there temporary. For this operation the /cache partition needs as many as 25 mb. If it hasn't, they might occur big problems.
    Furthermore, it's better to do it, because there isn't any software (e.g. recovery) which could go wrong.
    http://forum.oxygen.im/viewtopic.php?id=307
    S4 Mini (i9195) : AOKP 7.1.2
    SG Tab2 10.1 (P5100) : Beanstalk 6.0
    Nexus S (I9023) : SlimKat 4.4.2
    HTC Dream (G1) : Froyo 2.2.1 (CM 6.1.0)
