adb pull /system/app/StartupWizard.apk
adb pull /system/app/Wizard.apk
adb shell
rm /system/app/*Wizard*
rm /data/data/com.android.providers.settings/databases/*
mkdir /mnt/sdcard/cache
exit
adb push SetupWizard.apk /system/app/
on Tablet:
Settings > Device Info > Launch StartupWizard on next boot
Now you can reboot device. Instuctions for setup wizard:
press android ->
skip (!!) ->
tick both boxes -> -> ->
Settings > Apps > Manage > All -> clear cache+data for contacs storage + market
Settings > Accounts -> enable both background-data options -> reboot
DISABLE WiFi and use 3G until I tell you that you can re-enable WiFi!
Settings > Accounts -> add account -> et voila!
Wait until sync is done (the circle-arrow notificationbar icon) -> reboot
start market -> accept terms -> try to install an application > 2MB (eg: facebook) in order to check whether /cache is setup properly (if download fails or it force-closes something is wrong) -> reboot
Now enable WiFi start market and re-enter your password -> wait a bit and TADAA!!! Enjoy your AndroidMarket on 7cG2
