Non e che hai toccato le impostazioni reti mobili ?
Che operatore hai ?
Che operatore hai ?
ragazzi credo proprio che sia la zona perchè appena tornato a a casa funziona tutto perfettamente. grazie scusate.
il problema è tornato questo è l'output help me
I/TelephonyRegistry( 139): notifyDataConnection: state=0 isDataConnectivityPoss
ible=true reason=radioTechnologyChanged interfaceName=null networkType=3
V/DATA ( 218): [DefaultPhoneNotifier] : dun, IPV6, DISCONNECTED
V/DATA ( 218): [DefaultPhoneNotifier] : hipri, IPV4, DISCONNECTED
V/DATA ( 218): [DefaultPhoneNotifier] : hipri, IPV6, DISCONNECTED
V/DATA ( 218): [DCT] onUpdateDataConnections [ignored] : reason=dataNetworkA
ttached
D/NetworkManagmentService( 139): 200 default route replace succeeded for [rmnet
0 -4]
D/GTalkService( 239): ##### Network broadcast (connected=true) type=mobile, sta
te=CONNECTED
V/DATA ( 218): [DCT] onUpdateDataConnections: reason=radioTechnologyChanged
D/Tethering( 139): MasterInitialState.processMessage what=3
V/DATA ( 218): [DCT] ---dc list---
V/DATA ( 218): [DCT] cid = 0, state = DcActiveState, ipv = IPV4, ipaddress =
151.37.102.158, gw=151.37.102.157, dns=[212.52.97.25, 193.70.152.25]
V/DATA ( 218): [DCT] ---ds list---
V/DATA ( 218): [DCT] ds= SERVICE_TYPE_DEFAULT, enabled = true, active = v4:C
ONNECTED(0) v6:IDLE
V/DATA ( 218): [DCT] ds= SERVICE_TYPE_MMS, enabled = false, active = v4:IDLE
v6:IDLE
V/DATA ( 218): [DCT] ds= SERVICE_TYPE_SUPL, enabled = false, active = v4:CON
NECTED(0) v6:IDLE
V/DATA ( 218): [DCT] ds= SERVICE_TYPE_DUN, enabled = false, active = v4:IDLE
v6:IDLE
V/DATA ( 218): [DCT] ds= SERVICE_TYPE_HIPRI, enabled = false, active = v4:ID
LE v6:IDLE
I/DATA ( 218): [DCT] Ready for data :
I/DATA ( 218): [DCT] getDesiredPowerState() = true
I/DATA ( 218): [DCT] mCm.getRadioState() = RADIO_ON
I/DATA ( 218): [DCT] [DataRadioTech = RADIO_TECH_UMTS, data network state
= 0, mMasterDataEnabled = true, is Roaming = false, dataOnRoamingEnable = false
, isPsRestricted = false, desiredPowerState = true, mSIMRecords = true/22288, c
dmaSubSource = 1/, mRuimRecords = ]
V/DATA ( 218): [DCT] trySetupDataCall : ds=SERVICE_TYPE_DEFAULT, ipv=IPV6, r
W/DATA ( 218): [DCT] no working data profile available to establish service
type SERVICE_TYPE_DEFAULTon IPV6
V/DATA ( 218): [DefaultPhoneNotifier] : default, IPV6, DISCONNECTED
D/DATA ( 218): [DSST] pollstate() : reason = data network state changed
D/DATA ( 218): [DSST] Poll ServiceState done: oldSS=[0 home Wind Telecomunic
azioni SpA Wind 22288 UMTS CSS not supported -1 -1RoamInd: -1DefRoamInd: -1Emer
gOnly: false] newSS=[0 home Wind Telecomunicazioni SpA Wind 22288 UMTS CSS not
supported -1 -1RoamInd: -1DefRoamInd: -1EmergOnly: false]
I/3gwp.Service( 570): Mobile Network not connected - not roaming
I/3gwp.NetworkMonitor( 570): updateTraffic completed in 93 ms
I/3gwp.Service( 570): Mobile Network connected - not roaming
I/3gwp.NetworkMonitor( 570): updateTraffic completed in 66 ms
I/3gwp.NetworkMonitor( 570): updateTraffic completed in 36 ms
I/3gwp.NetworkMonitor( 570): updateTraffic completed in 128 ms
I/dun_service( 81): The value returned from dun_getusbmodemstate_fromsys is 2
I/TelephonyRegistry( 139): notifyServiceState: 0 home UMTS CSS not supporte
gOnly: false] newSS=[1 home Unknown CSS not supported -1 -1RoamInd: -1DefRoa
I/TelephonyRegistry( 139): notifyServiceState: 1 home Unknown CSS not suppo
E/DATA ( 218): Wrong network type: 0
V/DATA ( 218): [DefaultPhoneNotifier] : default, IPV4, DISCONNECTED
ible=false reason=dataNetworkDetached interfaceName=rmnet0 networkType=0
D/GTalkService( 239): ##### Network broadcast (connected=false) type=mobile, st
ate=DISCONNECTED
Nuovo Aggiornamento Custom Rom
E' passato un po' di tempo ed eccomi con le nuove versioni, tutte e tre utilizzano una tabella delle partizioni modificata, lo spazio disponibile con le mie versioni ora è:
60Mb circa per la cache contro i 4Mb dell'originale
140Mb per il sistema contro i 122Mb dell'originale
220 Mb per i dati contro i 294Mb dell'originale
Il ripristino delle impostazioni di fabbrica funziona correttamente su tutte le versioni.
Tutti i link e le istruzioni sono disponibili in prima pagina.
P.S. Il tablet mantiene comunque la possibilità di essere ripristinato con la rom stock da fastboot.
how did you remade the new partition sizes ?
did you remade the kernel ?
and also do you have the 0.4.6 stock rom somewere available for download ?
Ultima modifica di globula; 30-04-12 a 21:13
Hahaaaa !!! Lo sapevo !
Sapevo che saresti uscito con una versione nuova (ma addirittura tre, no) e quindi ho aspettato ad aggiornare il mio 7C.
Solo alcuni chiarimenti al riguardo.
Tra le caratteristiche della SG_base2_V.03 ce ne sono due:
- APN inseriti automaticamente come da rom originale (testati TIM e Wind)
- GPS funzionante
Vuol dire che nelle due versioni basate sulla Nano CFW Rev84, queste "caratteristiche" non sono così scontate ?
Seconda domanda:
"- Per la sola versione SG_Ibrida3_SD_V.10 le istruzioni sono valide solo se si utilizza una SD già partizionata con una seconda partizione che non supera i 2Gb di dimensione."
Sempre il (mio) caso con microSD da 16Gb, se usassi la SG_Ibrida3_SD_V.10, la "prima partizione" dovrà essere 14Gb e un zinzinino, mentre la seconda un zinzinino meno di 2Gb. Cosa uso, o meglio come mi consigli di partizionare ?
Vado di Win7, partizionandola e formattando la 14Gb in FAT32 e senza formattare la seconda o cosa ?
Terza domanda:
ma con le modifiche che hai effettuato sulla "cache/sistema/dati" (valide su tutte e tre le versioni) i problemi di applicazioni tipo Google Current che non si vogliono installare l'hai risolto anche sulla SG_base2_V.03 ?
Quarta domanda:
ma non è che la prossima settimana mi esci con una nuova versione ? Se no, aspetto !!
Ciao e grazie
setihalpha way MTD-Utils / re-partitioning MTD - Arnova 7c G2 Android and Firmware development | ARCTABLET NEWS
No, but my Base2 is the 0.4.6 with only few changes, root, market, flash player and default.prop.
i`m gonna use the base of your rom, to buid a new rom (i have problems with the gps on the 0.4.5)
thx for the info
Later Edit, why dod you inversed the keys on the recovery and the image is otherwisevery confusing
Ultima modifica di globula; 30-04-12 a 23:12
Leggi bene le caratteristiche delle altre versioni, ho scritto "Presenta tutte le caratteristiche della SG_base2_V.03"...
14 la prima e 2 la seconda senza bisogno di formattare la seconda.
Questa prova la lascio a te, installa la Base2 e poi facci sapere!
Ogni volta che avrò qualcosa di nuovo da inserire o qualche miglioramento da apportare farò uscire una nuova versione, cosa fai non aggiorni più?
Edit: Volevo aggiungere, data la tua rinomata "pigrizia" nel aggiornare il tablet, che le due versioni Ibrida3 attualmente disponibili sono "identiche", quindi se non ti serve una dimensione maggiore di 220Mb per installare le applicazioni puoi installare la versione NoSd.
Ultima modifica di simongabry; 01-05-12 a 07:52
