Utente del giorno: bluflight13 con ben 87 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: bluflight13 con ben 223 Thanks ricevuti negli ultimi sette giorni
Utente del mese: Sfattucci con ben 1156 Thanks ricevuti nell'ultimo mese
Pagina 3 di 8 primaprima 12345 ... ultimoultimo
Visualizzazione dei risultati da 21 a 30 su 75
[ROM] Porting cyanogenmod completato
  1. #21
    Androidiano VIP L'avatar di DanielVd
    Thanks
    15
    Quote Originariamente inviato da globula Visualizza il messaggio
    i`m uploading now the build
    maybe you can regain the adb logcat function of the rom so i can see what is happening with the wifi
    link:V9_CU_WIFI.zip
    the build is based on:
    -arnova boot image modified with stuff from the v9 image
    -the rom is from the v9 with the wifi related stuff from arnova.
    what i did ?
    i remade the path for the wifi driver, so the v9 uses the arnova`s original wifi path
    what i lost in the process is the adb logcat and the root process (the super user it is instaled but it seems that is not working)
    i bring here my release to, because i saw that also simongabry works on this
    you can find me, and my work on the arctablet forum
    So, in this version, the wifi starts but i can`t see any network
    Sorry because i writen in english, but i mannage better to express my ideas in this language (i dont know to write in italian without hundreds of mistakes, but i understand`it)
    don't worry friend
    Ultima modifica di DanielVd; 06-04-12 a 15:40
    Thanks
    12
    link:V9_CU_WIFI.zip
    what i did ?
    I sent you a P.M. with all the info, logcat and root are working fine with your version, wifi is not working.
  4. #23
    Thanks
    15
    Nel primo post la versione update-cm-7.2.0-RC1-v9-signed.zip
  5. #24
    Baby Droid L'avatar di simon3
    Thanks
    Quote Originariamente inviato da DanielVd Visualizza il messaggio
    Grande!!Provata!!=)!aspetto con ansia la funzione wifi/Gps/Sim con il porting dei nuovi driver! Y.Y
    Ultima modifica di simon3; 08-04-12 a 12:00
  6. #25
    Thanks
    15
    Quote Originariamente inviato da simon3 Visualizza il messaggio
    Sto lavorando di notte a sta roba
    Inviato dal mio HTC Wildfire usando Tapatalk
  7. #26
    Thanks
    how did you flashed the system, because every time when i flashed a version bigger then 88Mb, i was losing files from the rom
    Did you did something to the boot.img ?
  8. #27
    Thanks
    15
    Dopo un periodo di studio/lavoro alla rom sono tornato con nuove notizie.
    Nuova versione compilata.
    Novità:
    -accelerometro funzionante
    -record audio funzionante
    -galleria funzionante
    -tasti fisici funzionanti
    -audio non più funzionante al contrario delle altre versioni
    -alleggerita di molto la rom (vedi screenshoot)
    Immagini: https://picasaweb.google.com/1179748...eat=directlink
    Download nel primo post tra circa un'ora!
  9. #28
    Senior Droid L'avatar di foureight
    Thanks
    27
    Scusa Daniel me lo da corrotto !
  10. #29
    Thanks
    15
    Quote Originariamente inviato da foureight Visualizza il messaggio
    Lo ricarico
  11. #30
    Senior Droid L'avatar di SIRIOS.77
    In una ridente cittadina Veneta di nome Cittadella
    G i7500, G S, G Nexus, G SIII
    Thanks
    39
    Bella zio ... manca poco che fai società con google per via delle rom ...
  • Non puoi inserire repliche
