Sistemato il link
Sistemato il link
Fixata la fotocamera!
Ora fa le foto ma si blocca dui video!
Link: camera.zip
Flashate da recovery
Bravo, continua aspettiamo con ansia la definitiva
you should work with the stock arnova boot image as long as you use files from the stock rom
first example
21:26:41.653 Info WifiService 172 WifiService starting up with Wi-Fi disabled
21:26:41.698 Warning WifiHW 172 open(/sys/class/rfkill/rfkill1/type) failed: No such file or directory (2)
21:26:41.698 Error WifiService 172 Failed to start supplicant daemon.
The second error involves the boot.img that does not support that task and it has drivers mising. (21:26:41.698 Warning WifiHW 172 open(/sys/class/rfkill/rfkill1/type) failed: No such file or directory (2))
for example if you use the stock
21:19:45.439 Error HAL 172 load: module=/system/lib/hw/gps.default.so
you will need also the
21:19:45.439 Error HAL 172 Cannot load library: link_image[1962]: 115 could not load needed library 'libloc_api-rpc-qc.so' for 'gps.default.so' (load_library[1104]: Library 'libloc_api-rpc-qc.so' not found)
So, if you can make tests with the stock boot img (i tried to flash`it but it does not boots with this cm)
Visto che arnova non collabora i sorgenti me li procuro da solo.
Ecco una versione del boot.img che fixa parzialmente il problema del wifi!
Download: boot.img
Grazie Daniel, per il tuo grande impegno. Ma, ricapitolando, funziona tutto, tranne il Wifi che è al 50%, o sbaglio?
I`m gonna test this thing today and i will tell you my findings
bluetoth working
15:24:42.112 Verbose BluetoothEventRedirector 471 Received android.bluetooth.adapter.action.DISCOVERY_STARTED
15:24:42.442 Info ActivityManager 117 Displayed com.android.settings/.bluetooth.BluetoothSettings: +612ms
15:24:42.988 Error BluetoothEventLoop.cpp 117 event_filter: Received signal org.bluez.AdaptereviceFound from /org/bluez/680/hci0
15:24:42.988 Debug BluetoothService 117 updateDeviceServiceChannelCache(C4:46:19:F6:EA:5D)
15:24:42.988 Verbose BluetoothEventRedirector 471 Received android.bluetooth.device.action.FOUND
15:24:42.988 Debug CachedBluetoothDevice 471 Default to address. Device has no name (yet) C4:46:19:F6:EA:5D
15:24:43.422 Error NetlinkListener 70 ignoring message with no sender credentials
15:24:46.923 Error BluetoothEventLoop.cpp 117 event_filter: Received signal org.bluez.AdaptereviceFound from /org/bluez/680/hci0
15:24:46.923 Debug BluetoothService 117 updateDeviceServiceChannelCache(40:6A:AB:05:08:4E)
15:24:46.923 Verbose BluetoothEventRedirector 471 Received android.bluetooth.device.action.FOUND
The wifi is in the same position in which i tested the last times, i got the same results like now
Ultima modifica di globula; 25-04-12 alle 16:30
