nessuno che mi aiuta?
allora ho provato a fare il test con adb come e come specificato nella guida nella guida dovrebbe comparire cosģ:
C:\Program Files\Android\android-sdk\platform-tools>adb devices
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
list of devices attached
e logicamente il numero del device collegato
lanciando invece adb device mi risponde :
adb server is out of date . Killing....
*daemon start successfuly
e logicamente il numero del mio device collegato
č corretto? a me non compare
ma mi compare
pensate che posso fare il root? tf101g e B80
Salve, ho un TF101G modello B90 pensate che funzioni la suddetta procedura?
niente non mi funziona:
adb server is out of date. killing...
List of devices attached
043c71c543807057 device
C:\Program Files\Android\android-sdk\platform-tools>adb push nachoroot.bin /data
/local/
570 KB/s (15182 bytes in 0.026s)
C:\Program Files\Android\android-sdk\platform-tools>adb shell chmod 777 /data/lo
cal/nachoroot.bin
C:\Program Files\Android\android-sdk\platform-tools>adb shell /data/local/nachor
oot.bin --stage1
NachoRoot: ASUS Transformer Prime v1.1 Release Build
By Justin Case (jcase)
Presented by TeamAndIRC, RootzWiki and AndroidPolice
Testing by -viperboy-
I (jcase) do not have a Transformer Prime, I would like one to continue work on.
If you want to help by donating to my device/wine fund, please buy an app or use
paypal:
https://market.android.com/developer?pub=Cunning+Logic
https://www.paypal.com/cgi-bin/websc...id=U3JKACE7SN7
RC
Usage ./nachoroot.bin <parameter>
Parameters: DO NOT RUN OUT OF ORDER.
--stage1 : Reboots the Transformer
--stage2 : Reboots the Transformer again, and gains root..
--undo : This is your last step, after installing su/superuser, will fix instabi
lities from this root.
qui mi dą errore
Please reboot then run again with --stage2 parameter.
failed on '/data/sensors/AMI304_Config.ini' - Permission denied
link failed File exists
/data/local/nachoroot.bin: break: cannot break
mi potete aiutare?
Stessa cosa succede a me. Asus Transformers TF101 con stock ICS 4.0.3
Ma come cavolo si fa a entrare in recovery mode ???
Inviato dal mio Transformer TF101
Dovrebbe essere "Power+Vol down"
Sono stanco di tenerlo con ics ufficiale,non ci sono novitį per l'ultima versione OTA? Build 9.2.2.6 Mi vien da piangere :-) Altrimenti potete darmi un link/guida per fare un downgrade rootabile? Grazie!
Inviato dal mio GT-I9100
Mi trovo nella stessa identica situazione.. a me vien da pensare che il file del nachoroot non vada bene con android ICS.. o almeno con l'ultima versione rilasciata da Asus.. ma boh.. vediamo se si trova qualcosa in giro..
Ragazzi scusate perche la finestra dell Adb.exe mi si apre e si chiude subito?!?! come faccio a vedere i comandi?
Mi quoto nuovamente, ormai č dal 25-08-12 17:35 che non ricevo risposta. Ho spulciato per bene XDA e sebbene (senza offesa) quest'area del forum sia abbandonata, vi segnalo un metodo funzionante, gią testato da me, per rootare con successo il TFT101G conl a 9.2.2.6.
[TOOL]"1-Click Transformer Root"-Root/Unroot/cwm/stock rec-TF101(G)/201/300T(G)/SL101 - xda-developers
Pace!
