Update manuale Oreo
Salve gente, secondo voi potrei fare l'update manuale ad Oreo come descritto in un sito e che riporto qua sotto, oppure avendo lo zenfone con brand 3 avrei dei problemi?
Step01 First of all check device’s SKU version >Setting>>About >> Software Information >> Build Number & check software version is WW, CN, JP etc.
Step02 Visit on Asus official website to download Asus Zenfone 4 oreo firmware (WW_15.0405.1711.76) or (WW_15.0405.1712.83)
[Remember this firmware is only and only for SKU ww, don’t try to install it on [CN, TW, JP etc SKU]
Step03 File size is approx. 2.18GB, so make sure you are using a good internet speed network to download Asus Zenfone 4 oreo firmware or Stock ROM.
Step04 Once you are ready, rename the downloaded oreo firmware file as “Update.zip”, it’s important.
Step05 Now plug device with pc and transfer the “update.zip” file into your phone storage without any folder.
Step06 Boot Asus Zenfone 4 into “recovery mode” manually.
[Power off >> Press & Hold Volume up + power key together at the same time]
Step07 Once you are into “Recovery” mode, select “Apply update from sd card” and then browse the “update.zip” file from phone storage.
Step08 Android oreo update process will start and will take few minutes to flash complete oreo firmware on Asus Zenfone 4.
Step09 All Done!!! Enjoy the latest android 8.0 oreo version on Asus Zenfone ZE554KL.
