ciao ragazzi ho un problema con un linin prima pagina ,vorrei aggiornare alla 113 via usb ma non apre il link. qualcuno puo aiutarmi gentilmente?
h un gt1 board 9377 s912 stock firm 109
grazie raga
grazie raga
Segnalo che la rom android tv di Tilaz è arrivata alla versione 10. Ora necessita di essere flashata da burning tool.
[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate) - FreakTab.com
@panzer81
Garzie della segnalazione.
Il link della ROM Android TV è già presente neiu primi post.
Segnalo che la rom Android TV di Tillaz87 pare essere giunta alla sua versione definitiva (0.96). Ecco le feature.
This is Android TV based on the latest Shiningworth All-in-One firmware (Vorke_Z6-20171221) it supports all variants of the GT1 + other q201 boxes
I have brought back as much AOSP code as possible removing amlogic / vorke stuff that are not appropriate
Included:
System re-partitioned = 1 GB Extra for apps/data
4K YouTube + 60fps enabled + ads blocked
Enabled ATV Recant apps (Double press home button, Long Hold for assistant)
Long hold home button for google assistant (can use this on phone for mic)
Cyanogen homescreen clock/weather (Configure from app draw cLock)
Support for all Xbox/Sony Gamepads + Fixed select + home For Xbox Controllers
Fixed wireless Xbox 360 problem (left D-pad opening power menu)
ATV remote service (support for this)
Performance tweaks (RAM,CPU,IO) + init.d support
OpenGLRenderer (libhwui) Properties
Deodexed system, Ramdisk cleaned up, fully un-rooted, + removed from settings (root without prompt is a security risk)
Beelink remote fully working (Short cuts: Settings, Kodi, Chrome, Youtube)
Add back HDMI CEC settings (vorke removed it)
Fixed antutu and other 2D/3D games that use unity
Audio fixes aimed at antutu but for sure will apply elsewhere
Magisk can now be installed + safetynet will pass no need for any patch/module
Power menu now includes > suspend, shutdown, reboot, recovery (root not needed)
Improved media playback + lip sync fixed + Amcodec fixed
Updated Mali GPU driver + OpenGL 3.2 + Android extension pack (vorke use 3.0)
Fixed unrecoverable from sleep after long periods
Burn-in protection enabled (Oled TVs)
framework is now 99% AOSP 7.1.2 N2G48C
Code removed that was sending errors on home button press (linked to removed OEM stuff)
Removed code from services for /sys/class/leds/fd628_dev/ (vorke hardware)
Removed code from services that blocks play store updating (vorke)
Removed code from services that hides app not responding dialog (vorke)
TWRP: credit Magendanz
Zygoteinit changes to match AOSP + Missing DRM library's (L3) + Fixed mouse pointer size (vorke)
Recant Fixes:
Re-based on less buggy older vorke release
codec config fixes
AP6335 & AP4356 WiFi+BT fully supported
Binary cleanup
Performance tweaked again
Fix some freezing issues with 4k h265
Gapps updated
And probably more.. forgot to take notes to busy
Segnalo inoltre anche una patch che trasforma la rom da ATV in Android standard
Tutti i credits ovviamente sono di tillaz87
Ciao a tutti, ho un GT1 preso parecchio tempo fa, seriale A912xxx versione firm M110, l'update ota è bloccato per un aggiornamento da wifi andato male tempo fa ma l'ho sempre lasciato cosi com'è, pero ora mi è venuta voglia di provare qualcosa, il problema principale è che l'ultima app netflix funzionante è la 4.8 e se provo ad installare qualcosa di più recente quando avvio un video mi da errore (immagino per problemi DRM) ora leggo di questa versione android TV e se non ho capito male dovrebbe funzionare, dalla mia situazione come dovrei procedere per flashare il firmware? obbligatoriamente tramite cavo? che tipo di cavo necessita? ho anche letto di Burn_Card_Maker, non potrebbe essere utilizzato per riformattare il tutto?
Sperando che qualcuno mi possa indirizzare in modo preciso vi saluo e ringrazio
Ragazzi buonasera, sono possessore del gt1 a912 32 giga. Qualcuno può aiutarmi a settare il passtrought
In modo da poter utilizzare le codifiche del sintoamplificatore.
Ho provato anche con Kodi ma non riesco!!!!
seguo la ROM
Telefono attuale: REDMI NOTE 5 4/64
+ Galaxy S2 + Galaxy S4 + Nexus 5 + LG G2 + HONOR 8 BLU ZAFFIRO + Redmi Note 5 4/64
Ciao a tutti
ma sta ROM dove la si prende? non mi sembra ci sia nulla di nuovo ed il link di dropbox non funziona.
Quello che sono riuscito a scaricare dalla pag 1 è un multi iso di Mega che per di piu non capisco come unire:-(
@frannuce
Per favore servono i dettagli. Quale ROM?
Buongiorno ragazzi.. Problemino con l'aggiornamento, scaricato dal sito beelink la 109 via usb messa su chiavetta, lanciato aggiornamento, ma dopo un minuto si blocca e dice errore...
Problema del box o file corrotto? Perché non si dove trovarne un altro... Beelink rootato, con rom stock
Inviato dal mio ANE-LX1 usando Androidiani App
