Changed default locale in NULL
* now the phone will ask you the Language you want to setup
Added some xposed modules
Changed some build.prop lines
* now you'll be able to switch on/off the wifi using the toggle
* i deleted some lines for the ipv4/ipv6 calling settings, now you are able to call
and send SMS/MMS etc.
Added a /system/bin/recovery script, you can call it from a terminal session
Added ffmpeg to /system/bin, needed for the Advanced version
Fixed the GPS binary file and library
Fixed the USB Tethering mode
Added the Vitaminio codec
