D2 MTK6572 cinese
Ciao tutti, su uno dei siti pių diffusi di cineserie ho trovato il terminale di cui sopra a prezzo accattivante (99$ spedizione inclusa), vorrei sapere se secondo voi funziona pure (per un regalo natalizio) o č un cesso :-\. Vedo che ha poca memoria ma insomma non avrei problemi ad aggiungerci una micro SD. Le caratteristiche principali sono:
5.0" + Dual Network Standby + Android 4.2.2 + 1GB RAM + 4GB ROM + Wi-Fi + GPS + FM + 5.0MP Camera + 2.0MP Secondary camera + Dual-core
Copio e incollo le altre sotto. Grazie! ;)
Brand N/A
Model D2
Color White
Type Brand New
Form Factor Bar Phone
Operating System Android 4.2.2
Keyboard Touch Screen
Language Indonesian / Malay / Czech / German / English / Spanish / Filipino / French / Italian / Hungarian / Dutch / Portuguese (Brazil) / Portuguese (Portugal) / Romanian / Vietnamese / Turkish / Greek / Russian / Hebrew / Korean / Chinese
Networking GSM, WCDMA
Frequency 2G: GSM 850 / 900 / 1800 / 1900; 3G: WCDMA 2100 MHz
Data Transfer GPRS, HSPA, EDGE
SIM Type Ordinary SIM
SIM Slot 2
Network Standby Dual Network Standby
Network Conversation One-Party Conversation Only
Wi-Fi Yes
GPS Yes
Processor MTK6572 1.3GHz
CPU Type Dual-Core
GPU Mali-400 MP
RAM 1GB
ROM 4GB
Available Memory 2.4GB
Memory Card Supports Micro SD / TF card up to 16GB in size (not included)
Screen Size 5.0 Inch
Touch Screen Capacitive
Resolution 782 x 480 Pixels
Colors 260K
Camera 5.0 MP
Flash Yes
Auto Focus Yes
Video 640 x 480
Touch Focus Yes
Secondary Camera Supported Yes
Secondary Camera Lens 2.0 MP
Bluetooth Support V2.0
I/O Interface 1 x Micro USB, 1 x 3.5mm audio jack, 1 x mic, 1 x TF card slot, 2 x SIM card slots
Software Play Store, Calculator, E-mail, Clock, Calendar, Galleries, Music, Sound Recorder, Browser, Video Player, File manager, ToDo, FM Radio, etc.
FM Yes
TV No
Format Supported AVI, MP4, 3GP, MOV, MKV, FLV, FLAC, APE, MP3, OGG, AMR, AAC, JPG, PNG, BMP, GIF
Sensor G-sensor, Proximity, Light sensor
Battery Type Lithium Battery
Capacity 1800 mAh
Talk Time 140 Minutes
Standby Time 120 Hours
Manufacturer's Warranty 12 Months excluding physical damages (see specifications for terms and details)
Warranty Details 1-Year Manufacturer's Warranty: this warranty is offered directly by the manufacturer. Should the item become defective within the manufacturer's warranty period (physical damages and damages caused by incorrect usage excluded). customers may send the unit back to DX's Hong Kong office. DX will help forwarding the item to the manufacturer for repair or replacement. and will look after the progress. The customer will need to cover shipping fees both ways.
Packing List 1 x Phone
1 x AC power charger adapter (100~240V / 2-flat-pin plug)
2 x Batteries
1 x Earphones (100cm-cable / 3.5mm plug)
1 x Data cable (90cm)
1 x Flip case
1 x Screen protector
1 x English user manual
Beh, il prezzo č in parte giustificato, quel device non vale molto. Ecco i motivi:
1. Poca memoria, anche con sd potresti aver problemi.
2. Schermo grande e risoluzione bassa
3. I 5mpx cinesi spesso sono peggio dei 3mpx normali
4. Se hai bisogno della garanzia fai prima a buttarlo.
5. Indici sar alle stelle
6. materiali spesso scadenti
7. Schermo a 260mila colori quando ormai sono tutti a 16milioni
8. Video in vga
9. Bluetooth vecchissimo, ormai hanno tutti la v3 o la v4
Secondo me sarebbe meglio spendere qualcosina in pių e prendere un cellulare di una marca quantomeno conosciuta.
