Cube iWork 10 Flagship
E' finalmente in vendita il prossimo tablet flagship di Cube. Si aggiunge a tutti gli altri della categoria con 4Gb di RAM, 64Gb di storage e Intel Atom X5-Z8300. Anche questo con dual OS Windows 10 e Android 5.1.
Tutte le altre specifiche:
- Windows 10 + Android 5.1 dual systems: With more excellent interface, compatibility and running effect, the latest OS will lead you into a different world
- 10.1 inch screen: 1920 x 1200 pixels 10-point capacitive IPS screen offers wonderful experiences for watching videos and browsing the Web, supports Cube CEP02 Stylus touch pen
- CPU: Intel Atom X5-Z8300(Intel Cherry Trail Z8300) Quad Core 1.44GHz ( up to 1.84GHz )is equipped with better performance, delivering plenty of power for multitasking and fueling casual games and movies
- GPU: Gen8-LP10 / 12EU up to 600MHz is better and faster in playing games and watching videos than the previous generation
- RAM + ROM: 4GB + 64GB offers quick surfing online, video playing and gaming experience enhanced with DDR3L memory which makes all applications faster. Whether it is needed for work, study or play, it will suit your all needs
- TF card: Up to 128GB Max, you can download whatever you like to enjoy yourself
- Dual cameras: 2.0MP back camera with auto focus makes HD video recording more clearly and vividly, 2.0MP front camera for selfie
- 7500mAh battery: Large capacity helps you free from shortage of power and frequent charging trouble and delivers long battery life
- Gravity sensing system: Can fluently and sensitively run various applications
- Main functions: Supports Bluetooth 4.0, WiFi, OTG, HDMI, etc.
Alcune foto:
https://i.imgur.com/6Hz283y.jpg
https://i.imgur.com/QAkb61Q.jpg
Il prezzo sembra essere inferiore alla concorrenza, si aggira infatti intorno ai 170$.
Appena comprato e in viaggio dalla Cina! Qualcuno lo ha già testato?
Inviato dal mio Z1 usando Androidiani App
Discussione spostata nella nuova sezione Cube appena aperta.
arrivato un paio di settimane fa, aspetto notizie su modding e quant'altro su questo splendido tablet.
sopratutto sul root, ho visto delle guide su xda, ma non mi fido in quanto è il mio primo device con dualboot e non vorrei fare cavolate.
Ciao NiloGlock. Anche io sono tentato nel comprare questo tablet ma ho letto che la nuova versione type c ha dei materiali più scadenti tipo la ram a 1066 e la memoria interna non più Samsung ma Toshiba. Inoltre ho letto che la ricarica è lenta a causa della porta type c. Confermi? Grazie.
Arrivato da una settimana. Prime impressioni decisamente positive. Ottimo schermo e davvero impressionato dalla durata della batteria (arrivato a oltre 6 ore di uso intenso...). I materiali non danno senso di solidità nonostante lo spessore e il peso sopra la media. Processore e RAM fanno il loro dovere e non ho trovato particolari problemi con le app di android e di windows. Devo ancora verificare con i programmi più pesanti il comportamento... Presto ulteriori impressioni!
Inviato dal mio K6000 Pro usando Androidiani App
P.s. quello che ho io ha la usb3 in type b
Dove lo hai acquistato?
Gearbest. Piuttosto lenti ma alla fine è arrivato!
Attualmente hanno solo la versione type c che presenta i problemi da me descritti qualche post dietro.
