C'è una cosa però che mi sfugge:
parlando unicamente della versione 6/64 soltanto a me e al gentilissimo "carloperu" con l'ultimo aggiornamento si è manifestato questo odioso difetto ?
Se me lo facessi sostituire posso rifarlo sul telefono nuovo l'update o lascio perdere ed aspetto un prossimo aggiornamento ?
@Stahl letto solo ora, adesso provo !
Queste sono le prime 2 righe dello scatter ma non credo abbia nulla
Ho aggiornato ora SP FLash TOOLS e mi da errore 8417 che guardando in giro è proprio un errore dato da qualche valore prima dei cancelletti ma io non ho nulla! E' destino che io e il Mix non andiamo d'accordo..codice:############################################################################################################ # # General Setting # ############################################################################################################ - general: MTK_PLATFORM_CFG info: - config_version: V1.1.2 platform: MT6757D project: hct6757_66_n storage: EMMC boot_channel: MSDC_0 block_size: 0x20000 ############################################################################################################ # # Layout Setting # ############################################################################################################ - partition_index: SYS0 partition_name: preloader file_name: preloader_hct6757_66_n.bin is_download: true type: SV5_BL_BIN linear_start_addr: 0x0 physical_start_addr: 0x0 partition_size: 0x40000 region: EMMC_BOOT1_BOOT2 storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: BOOTLOADERS is_upgradable: true empty_boot_needed: false reserve: 0x00 - partition_index: SYS1 partition_name: pgpt file_name: NONE is_download: false type: NORMAL_ROM linear_start_addr: 0x0 physical_start_addr: 0x0 partition_size: 0x8000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: INVISIBLE is_upgradable: false empty_boot_needed: false reserve: 0x00 - partition_index: SYS2 partition_name: boot_para file_name: NONE is_download: false type: NORMAL_ROM linear_start_addr: 0x8000 physical_start_addr: 0x8000 partition_size: 0x100000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: INVISIBLE is_upgradable: false empty_boot_needed: false reserve: 0x00 - partition_index: SYS3 partition_name: recovery file_name: recovery.img is_download: true type: NORMAL_ROM linear_start_addr: 0x108000 physical_start_addr: 0x108000 partition_size: 0x1800000 region: EMMC_USE
