DOOGEE’s 2015 Flagship F3 will come in 1GB to 4GB of RAM versions.
    May 2015
    Doogee’s new high-end phone will come in during the first half of 2015, an will boast some really nice specifications MT6753 64bit, a Full HD 5 inch 2.5D display, 1GB, 2GB or even up to 4GB of RAM, there is even the possibility of a 3150mAh battery, and of course is a 4G phone. Internally, the phone will have at least 16GB of ROM.
    But what catches most the eye about this phone is the design, with a really stylist metal frame and Gorilla glass in the back and front in the standard version and wood or bamboo as an option for the back.
    Basic spec:
    Screen: 5.0 inch, 2.5D curved glass, 1mm bezel
    Resolution: could be FHD,1080P
    Battery: could be 3150mAh
    Camera: front 8.0mp OV, rear 13.0MP SONY IMX214 or Samsung Icosell
    CPU: MT6753 LTE SoC64bit octa Cortex-A53 1.5Ghz
    GPU: ARM Mali-T760
    Colors: Deep Blue, White Pearl.
    System: Android Lollipop 5.1, Ubuntu (still not confirmed)
    Androidiani Power User L'avatar di leonbeson
    Sull'Adda
    N6P, N5 e il mitico i9001
    Ringraziato 1,168 volte in 825 Posts
    TD chiuso. Si prega l'utente autore del TD di contattarmi nel caso volesse vederlo riaperto e di apportare subito dopo un'adeguata traduzione in italiano.
