E odin? Lo rileva?
E odin? Lo rileva?
2 giga free online? [link rimosso ]
No come ti dicevo odin non lo rileva mentre se invece di odin uso i comandi di adb il telefono è riconosciuto...
Ho installato kies e ora con odin lo vede!!!! Cosa mi consigliavi di fare con odin?
Scaricare la factoty image e flasharla con odin
Fatto ma mi da failed, ecco il log:
<ID:0/008> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> odin.takju.jwr66y.4.3.tar.md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/008> Odin v.3 engine (ID:8)..
<ID:0/008> File analysis..
<ID:0/008> SetupConnection..
<ID:0/008> Initialzation..
<ID:0/008> Set PIT file..
<ID:0/008> DO NOT TURN OFF TARGET!!
<ID:0/008> Get PIT for mapping..
<ID:0/008> Firmware update start..
<ID:0/008> SingleDownload.
<ID:0/008> boot.img
<ID:0/008> NAND Write Start!!
<ID:0/008> bootloader.img
<ID:0/008> radio.img
<ID:0/008> recovery.img
<ID:0/008> system.img
<ID:0/008> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
Ultima modifica di nbusato; 17-05-14 alle 14:12
Con fastboot il processo lo completa ma al reboot c'è ancora la Cyanogenmod e mi trovo al punto di partenza.... sembra sia tutto in read only:
C:\Program Files\Minimal ADB and Fastboot>fastboot flash bootloader bootloader-maguro-primemd04.img
sending 'bootloader' (2308 KB)...
OKAY [ 0.242s]
writing 'bootloader'...
OKAY [ 7.939s]
finished. total time: 8.183s
C:\Program Files\Minimal ADB and Fastboot>fastboot reboot-bootloader
rebooting into bootloader...
OKAY [ 0.008s]
finished. total time: 0.010s
C:\Program Files\Minimal ADB and Fastboot>fastboot flash radio radio-maguro-i925
0xxlj1.img
sending 'radio' (12288 KB)...
OKAY [ 1.246s]
writing 'radio'...
OKAY [ 4.390s]
finished. total time: 5.638s
OKAY [ 0.009s]
finished. total time: 0.011s
C:\Program Files\Minimal ADB and Fastboot>fastboot -w update image-takju-jwr66y.zip
archive does not contain 'boot.sig'
archive does not contain 'recovery.sig'
archive does not contain 'system.sig'
Bootloader Version...: PRIMEMD04
Baseband Version.....: I9250XXLJ1
Serial Number........: XXXXXXXXXXXXXXXX
checking product...
OKAY [ 0.008s]
checking version-bootloader...
OKAY [ 0.010s]
checking version-baseband...
OKAY [ 0.010s]
sending 'boot' (4376 KB)...
OKAY [ 0.451s]
writing 'boot'...
OKAY [ 2.546s]
sending 'recovery' (4924 KB)...
OKAY [ 0.553s]
writing 'recovery'...
OKAY [ 4.518s]
erasing 'system'...
OKAY [ 0.008s]
sending 'system' (479248 KB)...
OKAY [ 48.629s]
writing 'system'...
OKAY [1614.249s]
erasing 'userdata'...
OKAY [ 0.034s]
formatting 'userdata' partition...
Creating filesystem with parameters:
Block size: 4096
Blocks per group: 32768
Inodes per group: 8144
Inode size: 256
Journal blocks: 32768
Label:
Blocks: 3549691
Block groups: 109
Reserved block group size: 871
Created filesystem with 11/887696 inodes and 97200/3549691 blocks
sending 'userdata' (137559 KB)...
writing 'userdata'...
OKAY [262.507s]
erasing 'cache'...
OKAY [ 0.007s]
formatting 'cache' partition...
Block size: 4096
Inodes per group: 6912
Inode size: 256
Journal blocks: 1728
Label:
Blocks: 110592
Block groups: 4
Reserved block group size: 31
Created filesystem with 11/27648 inodes and 3566/110592 blocks
sending 'cache' (8832 KB)...
writing 'cache'...
OKAY [ 15.469s]
rebooting...
finished. total time: 1949.369s
Dico la verità. Non conosco uno strumento che scriva più in profondità di odin.
Forse esiste un tool alternativo che se non sbaglio si chiama heimdall. Ma non l'ho mai provato. Non so se il cyanogen installer sia anche reversibile
In teoria la procedura manuale e quella tramite toolkit dovrebbero essere uguali, ma a me è successo che con il toolkit non funzionava, mentre in manuale si. Prova a seguire la procedura manuale descritta da nexuser, è molto chiara
EDIT: prova a reinstallare i driver. Il ho avuto lo stesso problema ed erano i driver danneggiati, infatti la stessa procedura nel mio PC non funzionava, in quello di nexuser si.
Ultima modifica di ferrarista10; 17-05-14 alle 20:03
Ciao, niente provato da un altro pc ma stessa cosa.
Ho trovato altri 2 post di 2 utenti che hanno lo stesso problema ma non hanno risolto ancora :https://www.androidiani.com/forum/mo...ml#post5538758
https://www.androidiani.com/forum/mo...ml#post5532229
