L'autore del toolkit per l'N7 ha messo disponibile per i sostenitori del suo progetto un update per il nuovo modello 4.2.2
NEXUS 7 TOOLKIT AUTO UPDATE V4.3.4 [17TH FEB 2013] AVAILABLE!!
Changelog:
+Added FULL support for yakju/takju 4.2.2 Jelly Bean builds [everything works perfectly]
+Added insecure boot image for 4.2.2 JDQ39 build for Nakasi and Nakasig for more stable operation
+Updated google adb + fastboot files so device can connect on 4.2.2
+Uploaded google stock images for 4.2.2 to goo.im and added links to Toolkit
+Fixed several parts of code and made improvements
+Completely restructured Toolkit code for future Toolkit integration
I tried to get this out as soon as possible for people who are facing problems with 4.2.2 after updating. This update should fix everything and I will be updating all the other Nexus Toolkits over the next day. I can then finally start building the next set of public versions.
[Auto Updates are only accessible if you have donated to the Toolkit project, received an activation code and unlocked the donator features. Auto Updates are a much faster and easier way of pushing small updates that would otherwise not be worth doing. I can push a single textual change or add support for a new build without having to go through the whole process of building a full version and uploading a large file. IF you are not able to or do not want to donate to unlock the Auto Update feature (and other donator features) then all the smaller updates are collated and a full build made when I have time or if there are enough updates to warrant it. This is the easiest way to make sure all the Toolkits are as up to date as possible. IF you have any views about this please pm me about them and do not post in the open thread]
Thread Link: [Google Nexus 7 TOOLKIT V4.0.0] Drivers, Backup, Unlock, Root, CWM, Flash + MUCH MORE - xda-developers
Enjoy
Mark
