Andreamer
Qui vendono un prodotto specifico, però non garantisco!
Displex Touch Screen Polish
Product Id: 26673
Only: $12.99
Instead of replacing your scratched phone, repair you screen with Displex LCD Scratch Remover. The cost-effective display polish provides customers with a simple solution for their scratched displays. The do-it-yourself paste is applied under pressure to the scratched screen. The results are spectacular! The tube holds approximately 8-10 applications.
Product Features:
• Replaceable cap for multiple uses
• Easy to use paste
• To be used on screens only
