Add-on's, Themes, Tips!
Add-on's
HTC IME - Here (if you keep getting FC's, check its installed on internal memory!)
ADFREE - can be downloaded from the market.
ADFREE PLUS - Made and maintained by Dnlgee! A much better adblocker!
This is a flashable .zip (in recovery) by Dnlgee (AdFree only uses the MVPS database which isn't updated too often.. So I use MVPS, Peter Lowe's and Host-File.net to increase the amount of ads and tracking sites blocked. This also includes some referral sites.) Download HERE Please remember to say thanks if you see him about!
Music app from HONEYCOMB with Sync! - Flashable .zip made by me! - Here..
Original Gingerbread Music.apk - Download from my Dropbox - Signed flashable .zip
Menu Wake MOD ON (flashable.zip) - Here Flash via recovery! Made by Me!
Menu Wake MOD OFF(flashable.zip) - Here Flash via recovery! Made by Me! to Revert back to normal.
Bootanimation for Oxygen (original) - Here
Wallpaper for Oxygen (original) - Here
The NEW Market 2.2.7 - Here *(signed test-keys)*
Black Market 2.2.6(old style) - Here by djDarkknight96 This is the normal market old style just in black!
3D Gallery (high res) - Here by Number22
2D Gallery (old) - Here
GAPPS (Google standard apps) - Here
GenieWidget.apk - Here This is the stock news and weather widget should you need it!
Themes
ClockR MOD - Here (this is very, very cool mod, check it out!) by zehro
Kbanause Theme - Here by Kbanause -Must see!
Battery % Mod - Here by classicalGas
PureOxygen MOD - Here by Jazzk
Circles Mod Oxygen - Here. - Must see! by Hooolme
ProperBlack Theme for Oxygen - Here Nice theme mod, Check it out! by str355
Oxygen RC2 theme by rover.prince - Here, Check it out for screen shots! *added circles mod to theme Updated 23/12/10*
INexus port for Oxygen - Here by dboy0911! Check it out!
UOT Kitchen - Here UOT kitchen is a complete Theme making kit, for instruction visit the link supplied! (for 1.0.4)(just batt symbol on RC1 gingerbread)
Android Theming and Tweaking V2 - Here A complete Theming and tweaking solution for Android by Shoey-n
Green Icons Oxygen v2 RC1 - Flash the zip downloaded from HERE
Tips
Oxygen Updater - The updater is located in your app draw on your desire!, To use just open it up, and click "check for updates" after a successful download you can either flash the zip right away or quit and reboot into recovery and do a nandroid backup first (Highly recommended)
Market Issue (No comments shown) - In order to see the comments, You must remember to set your locale in settings first!. (This also sorts out numbers issue on the gingerbread keyboard). Thanks to bernabap
Youtube & Google Maps FC's (force close's) on RC3 - Install Youtube from the market. Then If any more problems, Uninstall and reinstall again, seems to sort it.
DropBox *extra 250mb with this link* - Use this to sync files from your Pc and Android phone automatically. Highly recommended.
Make Flashable .zip files Thanks to Dakata
OxygeN FaQ. PDF Download 308kb.
- Updated 4/1/2011
