THREAD Ufficiale XDA: [ROM][Mar 05 2013] MildWild MW-9.5 Based on Redux2 TEST - xda-developers
MildWild Jelly-Gingerbread
Versione MildWild CM-8 JG Stable
Prerequisiti:
1) Root , S-OFF
2) Recovery moddata ( ClockWorkMod , AmonRA, 4EXT etc)
3) Partizione EXT3/EXT4 da 1GB
4) Hboot Stock
Installazione:
1) Scaricare lo zip della Rom
2) Avviare il telefono in Recovery
3) Fare tutti i wipe , se arrivate da una Rom diversa o se state flashando una versione aggiornata di questa Rom con build differente
4) Riavviare il telefono e buon divertimento!
Se non dovesse andare il Gps seguire questa guida
[GUIDA][GPS] AGPS Patch - GPS Assistito
Features Redux2 TEST:
* FM radio support;
* Built-in FTP server functionality, so there's no need for a cable when transferring files;
* Multitasking panel, with quick access to common settings and multimedia controls.
* Trackball wake
* music controls
* Playback control via the volume keys
* the foreground application by long-pressing BACK
* LED notifications improvements
* Option to turn overscroll glow off
Features MildWild MW-9.5:
[B][SIZE="4"]* Gingerbread 2.3.7
* Kernel Thalamus 2.6.35.14 mod by:"island3r"
* Fast
* Jelly Bean Theme
* Jelly Bean transition animations
* XperiaLauncher
* MIUI Camera
* More Android String Translation
* GPS mod.
* 720p HW PLAYBACK
* Disable CPU Rendering
* LatinIME ICS Style and Option to reverse volume key logic on cursor control
* Xperia Launcher Port.
* Dalvik cache is moved to SD
* "froyo style" apps2sd, it also supports A2SD with an EXT3 or EXT4 partition.app2sd is enabled
* Ice Cream Sandwich (theme)
* Swipe to Clear Notifications
* MOTOBLUR DeskClock Alarm (Clock -> Alarm -> Settings -> Alarm Alert Screen -> MOTO BLUR)
* T9 dialer
* MVPS hosts file to block ads, banners, etc.
* IO performance
* Hardware rendering
* Flac support
* Many more sytem tweaks
Changelog MW-9.5:
* Smaller size
* Fixed Theme
* Update SuperSU
* Update Host`s
* More speed in UI
No Time for more..sorry
keep in mind that the development of Redux2 is stopped and closed source so some things can't be fixed..
