Ok, mettendo la recovery dell'hero posso usarla senza che si riavvii, ma quando carica il firmware si riavvia lo stesso.
Ora non mi resta che tornare agli spl e radio originali riflashandoli dalla recovery?
Dalla recovery modificata puoi installare la rom CursorDroid 1.0, che trovi su XDA.
Se vuoi installare altre rom, devi necessariamente fare il downgrade della radio e dell'SPL. La procedura è spiegata qui:
Downgrade (Revert back to) 32A 3.22 Radio and SPL
You will need:
- 1.33.2010 Engineering SPL HBOOT image
http://www.theandroidkitchen.com/fil...-1.33.2010.img
- 3.22.20.17 Radio image
http://www.theandroidkitchen.com/fil...3.22.20.17.img
- Amon_RA Sapphire H Recovery (Latest is 1.5.2 as of this post)
[Recovery] [32A & 32B] [13-Dec-2009] RA-sapphire-v1.5.2 - xda-developers
Steps:
- Download all of the files to the same folder (C:\AndroidSDK\tools for example)
- Turn off your phone
- Power it on into FASTBOOT by holding Back and pressing Power
- In a Command Prompt, navigate to the folder you saved the files in
- Type in these commands:
Code:
- Your phone will reboot back into FASTBOOTcodice:fastboot flash radio Radio_HTC_PVT_32A_3.22.20.17.img fastboot flash hboot hboot-1.33.2010.img fastboot flash recovery recovery-RA-sapphire-v1.5.2H.img fastboot erase system -w fastboot reboot-bootloader
- Verify that you now have 3.22.20.17 SPL and 1.33.2010 SPL
Galaxy Nexus masterrace
LG Optimus one
HTC Magic TIM white
