qualcuno potrebbe aiutarmi a capire le due righe evidenziate? non capisco dove devo mettere le tre apk , non trovo nessuna cartella data/preload
Download stock Backup and Recovery from links above. Unzip Stock Backup folder from Zip file
2: Place stock back up in folder "TWRP/Backups/FA3APWG02523" and restore via TWRP
3: Flash SuperSU file (I know you have this file)
4: Now reboot and Download 3 files from https://www.dropbox.com/s/vl7bwh5b5q...ing%20APKs.zip and copy these to "data/preload" using any Root Browser
5: Now reboot to bootloader and flash stock recovery in fastboot mode "fastboot flash recovery recovery_t6ul-2.61.401.3.img"
6: Relock Bootloader in fastboot mode "fastboot oem lock" or use Scotty123 method to "Lock" your bootloader: http://forum.xda-developers.com/show....php?t=2540004
7: Boot into Stock Recovery and factory rest (please back up all your data from internal SD Card because factory reset will wipe everything)
8: Now boot up your phone and you should be seeing everything Stock now.
