Base 1.17.401.1
Android 4.1.1 with Sense UI 4+.
Multilingua
Deodexed, Recompressed & Zipaligned
SuperSU, Busybox.
Persistent ADB enabled.
Supporto init.d
Ram tweaks
Opzione per rimuovere app (Aroma installer)
Opzione per installare nuove mod (Aroma installer)
Eccellente durata della batteria.
Supporto 24h al giorno
Molto altro!!
- Fixed Rosie FC - Only for those who flashed ROM after a full wipe.
3.2.1
- Optimized battery life.
- Fixed and improved camera.
- Updated Google Play Services.
3.2.0
- Reoptimized all apks and framework files using SDK r21.0.1.
- More free RAM, less battery usage.
- Faster loading of apps, and overall improved performance.
- Updated Google Maps.
- Updated AdAway hosts file.
- Fixed disable exchange security mod.
- Cleaned build.prop.
3.1.1
- Updated Google Plus.
- Updated Apex launcher.
- Added option to remove unneeded keyboards in AROMA.
3.1.0
- Fixed reboot binary.
- Improved APM icons.
- Updated Google Play Store.
- Updated Facebook.
3.0.0
- Rebased on 1.17.401.1.
- Updated Google Now.
- Updated SoundHound.
- Updated Flash Player.
- Updated Nova launcher.
- Fixed bug with sound set.
- All previous mods, tweaks and fixed included.
- Other minor changes and fixes.
2.1.1
- Added Rosie with menu support.
- Updated Facebook.
- Updated Dropbox gallery fix - Thanks lyapota.
2.1.0
- Removed 3-dot menu.
- Remapped recent apps button to menu button.
- Updated Gmail.
- Updated SuperSU.
- Updated Dropbox.
- Updated Facebook.
2.0.0
- Rebased on 1.16.401.6.
- Improved scrolling performance.
- Increase WiFi connection.
- Fixed music player bug in car mode.
- Fixed inaccessible downloaded photos in Twitter.
- Fixed under map view crash.
- Updated Talkback.
- All previous mods, tweaks and fixes are included.
1.1.0:
- Fixed updater-script so it won't format sd card.
- Improved battery life.
- Added few missing apks.
Sbloccare via HTCDev (saltate se avete già sbloccato)
Installate una recovery custom
Scaricate la rom e copiatela nell'sd virutale
Scaricate il boot.img e flashatelo da fastboot tramite il comando: fastboot flash boot boot.img
Per evitare problemi con il nuovo boot date: fastboot erase cache
Andate in recovery e flashate la nuova rom
Riavviate e divertitevi
09-12-12, 17:50
Rusie
scusa l'ignoranza ma....... il file della recovery custom quale è????????? e come si installa?
09-12-12, 19:05
iGuich
Originariamente inviato da Rusie
scusa l'ignoranza ma....... il file della recovery custom quale è?? e come si installa?
La recovery da installare la trovi nel thread in rilievo.
Il boot.img è il kernel della rom :)
27-12-12, 17:53
matiu
Rom aggiornata qualche giorno fa alla versione 3.2.1 con diverse novità, la consiglio perchè è stabile veloce e con una buona durata della batteria, inoltre lo sviluppatore è molto presente nel topic ufficiale. ;)
27-12-12, 18:41
mackzone
Installata una settimana fa, mi ci trovo molto bene :)
19-01-13, 10:25
blademetal
qualcuno percaso ha fatto un test con antutu su questa rom? mi interessava sapere soprattutto il risultato della ram
