problema root
ciao ragazzi ! sono giorni ormai che provo a sbloccare il mio htc sensation xl Beats studio.
sono riuscito a sbloccare il bootloader ( mi compare la scritta UNLOCKED quando lo avvio con power+VOL )
però non riesco ad acquisire i permessi di root !
premetto che ho già letto le vostre guide e non hanno funzionato .. :(
in particolare il cellulare si riavvia senza superuser , e nel prompt dei comandi mi compare :
CONFIRM ALL THE ABOVE THEN
Premere un tasto per continuare . . .
--- STARTING ----
--- WAITING FOR DEVICE
adb server is out of date. killing...
ADB server didn't ACK
* failed to start daemon *
error:
--- cleaning
* daemon started successfully *
rm failed for *, No such file or directory
--- pushing zergRush"
1876 KB/s (23056 bytes in 0.012s)
--- correcting permissions
--- executing zergRush
--- WAITING FOR DEVICE TO RECONNECT
if it gets stuck over here for a long time then try:
disconnect usb cable and reconnect it
toggle "USB DEBUGGING" (first disable it then enable it)
--- DEVICE FOUND
* daemon not running. starting it now *
--- pushing busybox
2447 KB/s (1075144 bytes in 0.429s)
--- remounting /system
mount: permission denied (are you root?)
--- copying busybox to /system/xbin/
/system/xbin/busybox: cannot open for write: Read-only file system
--- correcting ownership
Unable to chmod /system/xbin/busybox: No such file or directory
--- installing busybox
/system/bin/sh: /system/xbin/busybox: not found
--- pushing SU binary
failed to copy 'files\su' to '/system/bin/su': Read-only file system
Unable to chmod /system/bin/su: No such file or directory
--- correcting symlinks
rm failed for /system/xbin/su, No such file or directory
link failed Read-only file system
--- pushing Superuser app
failed to copy 'files\Superuser.apk' to '/system/app/./Superuser.apk': Read-only
file system
--- cleaning
--- rebooting
aiutatemi pleaaaaseee :)
