jeremix
Installa UPDATE.APP dalla microSD cartella dload riavviando con tasti power , vol+ e vol- contemporaneamente , se anche così non và potrebbe essere una cosa seria
Hard Reset HUAWEI ASCEND G510 U8951 with MicroSD card Firmware Update :
Make sure the battery if fully charge
Turn off the HUAWEI ASCEND G510 U8951
Remove the MicroSD and connect to computer or PC
Download firmware from computer browser
http://www.huaweidevice.com.
Choose the HUAWEI ASCEND G510 U8951 support and download the same version of firmware or update firmware
Extract the downloaded folder, and copy all folder (include folder) into main root location of MicroSD
Insert again the MicroSD to HUAWEI ASCEND G510 U8951
Turn on Phone together with press and hold Power + Volume Up + Volume Down button until the Android logo appear
Wait the process of update or reinstall the firmware will be less then 10 minutes.
