Non riesco ad individuare l'errore nel programma
    Lecce
    Defy+ & Acer liquid A1
    Salve ragazzi non riesco a trovare l'errore nella mia app ecco il logcat:
    12-04 01:05:33.062: W/dalvikvm(5536): threadid=1: thread exiting with uncaught exception (group=0x2aac87c8)
    12-04 01:05:33.122: E/AndroidRuntime(5536): FATAL EXCEPTION: main
    12-04 01:05:33.122: E/AndroidRuntime(5536): java.lang.ArrayIndexOutOfBoundsException
    12-04 01:05:33.122: E/AndroidRuntime(5536): at it.bisemanuDEV.prodMatrix.TerzaAttivita$2.onClick( TerzaAttivita.java:152)
    12-04 01:05:33.122: E/AndroidRuntime(5536): at android.view.View.performClick(View.java:2408)
    12-04 01:05:33.122: E/AndroidRuntime(5536): at android.view.View$PerformClick.run(View.java:8819)
    12-04 01:05:33.122: E/AndroidRuntime(5536): at android.os.Handler.handleCallback(Handler.java:603 )
    12-04 01:05:33.122: E/AndroidRuntime(5536): at android.os.Handler.dispatchMessage(Handler.java:92 )
    12-04 01:05:33.122: E/AndroidRuntime(5536): at android.os.Looper.loop(Looper.java:123)
    12-04 01:05:33.122: E/AndroidRuntime(5536): at android.app.ActivityThread.main(ActivityThread.jav a:4627)
    12-04 01:05:33.122: E/AndroidRuntime(5536): at java.lang.reflect.Method.invokeNative(Native Method)
    12-04 01:05:33.122: E/AndroidRuntime(5536): at java.lang.reflect.Method.invoke(Method.java:521)
    12-04 01:05:33.122: E/AndroidRuntime(5536): at com.android.internal.os.ZygoteInit$MethodAndArgsCa ller.run(ZygoteInit.java:868)
    12-04 01:05:33.122: E/AndroidRuntime(5536): at com.android.internal.os.ZygoteInit.main(ZygoteInit .java:626)
    12-04 01:05:33.122: E/AndroidRuntime(5536): at dalvik.system.NativeStart.main(Native Method)
    Lecce
    Grazie lo stesso ma ho risolto
    Forse andavi un record oltre l'array?
    Lecce
    si era proprio quello il problema
