ok thx a lot
i'm curious why my reply was not shown in your thread though i have tried it several times
ok thx a lot
hello
I installed the new v8 version on v7 but I have a poblem'
I lost my Bluetooth connection with my with Garmin Fenix 3.
Impossible reconnection.
With the v7 function good.
I have tried a full wipe wipe with a clean install of v8.
I reinstall the v7 on the v8 and my Bluetooth connection with my watch has come back
I did not change anything about the bluetooth between v7 and v8
maybe the new blobs of 3.53 have messed something
I'm working with new blobs of 3.54, in one or two days I will release the V9
securecrt (25-08-15)
link Release V9 and changelog in first page
hellow paol.
i have some questions here.
1.i heard from u that " in YIOS the thermal engine it is not working properly and consequently the frequency of the CPU and GPU remains low (which is why AnTuTu score is 30k-35k)
however in this rom the thermal engine works properly, the frequencies are raised and obviously also increases the heat"
what's the thermal engine? u mean if it is not working properly , it can't use themes? when i use yios, it can change themes , i want to know which features would be affected because of thermal engine is not work.
2. when i use v6 v7 v8 . i am not test for otg feature.
when i use v9 , otg is not work, when use U disk, U disk‘s lights are not flashing,and phone can't found udisk..
when i use usb Mouse, it's lights are flashing but no arrows on the phone screen.
when i use YIOS , otg is work OK.. if because of i flasing your rom with out full wipe??
