Wow. I really wish I had your energy Way to go Paolo! And, if I may add, you're better at keeping hardware updated than loads of original manufacturers
Battery drains very fast with v17, i'' have to download v16 again.....
Hello, sorry if i asking stupid questions, but im newbie, and i don't know what means "only for merged partitions". What must i do to merge partitions? Somebody have detailed instructions how to install this ROM? And other question - i already have official 1.50 nubia rom, it's android 4.4.4, do i need to install later official ROM, or mine will be sufficient? Thank you for any help.
The official 4.4 ROM has two partitions, while the newer Android 5.0 official ROMs merge the partitions into one big data partition. The first guide for upgrading is located here:
http://forum.xda-developers.com/zte-...p-5-0-t3053880
You shouldn't use this one but it explains things nicely.
You want to upgrade to a newer version of the official ROM, and I'd recommend 3.09 (others may work but I have experience with that one). Here's a link to 3.09 that also has a newer upgrade guide:
ROM Nubia Z7 Max v3.09 | [Official] add the 04/28/2015 on Needrom
After that, you should follow Paolo's guide.
Any more questions, feel free to ask
PaoloW8 (05-11-15)
Thank you so much RoboTrigger. I'll give a try.
Happy Birthday Paolo. Health and long life to you.
PaoloW8 (06-11-15)
Happy birthday, keep going
PaoloW8 (06-11-15)
Happy birthday Paolo. Thanks to make our phone a better phone
PaoloW8 (06-11-15)
PaoloW8 (06-11-15)
