thank you for your reply.
the problem will happen when the proximity detects the face and turns off the screen. you can block the proximity sensor during a call and hang up from the other side such that the problem will occur.
Many thanks!
originally the option "prevent accidental wake-up" was on and i had that problem.
i just turned this option off and tested it again. the problem still exists.
in fact this problem can be solved by switching "double tap to wake" off. but i would like to use the "double tap to wake" function. thank you for your help.
you can post a screenshot of the properties of the file "/data/tp/easy_wakeup_gesture" ? I need to know which touchscreen you have (there are 2 or more types of touchscreen)
you can do with the cm file manager (after enable root) or root explorer
when i switch on the function "double tap to wake", the value in the file "/data/tp/easy_wakeup_gesture" is 0x01 as shown below.
when "double tap to wake" if off, the value becomes 0x00.
thank you for your attention.
yes is right
but i need the properties of the file like this
sorry for misunderstanding you
don't why that screenshot is so small...
Ultima modifica di no1chan; 27-07-15 alle 08:59
yes is too small, i can't read the Link lines
or you use a web site to host the image (like Imgur) or write the link line
try this
PaoloW8 (27-07-15)
