yes you can, no wipe needed
after the update if you see some problem (data not working or no sim detected or something like that) just flash again the old version
Hi Paolo!
Thanks for your quick reply!
Regards
I just found this new version #23
Can I just install it on the #22 version without wipe?
Apparently,I could
