Pagina 2 di 50 primaprima 123412 ... ultimoultimo
Visualizzazione dei risultati da 11 a 20 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #11
    you can try the open gapps (added today, this morning there were not)
    opengapps.org
    edit:
    it seems that does not work, the phone stops on the boot animation
    Ultima modifica di PaoloW8; 06-11-15 alle 20:42
    Nubia Z7MAX
    Jul 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    for contacts seems to go a bit of time, I found them after a couple of hours
    start the contact app and try to add the same google account, It will tell you that the account is already in the phone but maybe unlocks something
    However the problem is the gapps
    I've tried many versions, most are not usable (fc constantly)
    I tried several times. Did not work.
  4. #13
    Quote Originariamente inviato da mai62 Visualizza il messaggio
    I'm uploading a new version of gapps (10-15 min to finish)...I added the calendar sync and a new contact sync apk (taken from open gapps)
    Nubia Z7MAX
  5. Il seguente Utente ha ringraziato PaoloW8 per il post:
    mai62 (06-11-15)
  6. #14
    new gapps: gapps-mm-mini_newversion.zip
    flash with cache and dalvik cache wipe
    if not works open settings->apps->menù button->show system->search google contact sync->permission and check if contact is enabled
    you can also check the permission of google play service, google service framework, google account manager, google backup transport
    Ultima modifica di PaoloW8; 06-11-15 alle 21:20
    Nubia Z7MAX
  7. Il seguente Utente ha ringraziato PaoloW8 per il post:
    brooklyn2006 (08-11-15)
  8. #15
    Jul 2015
    Thank you! Now, contacts and calendar are synchronized. I checked the permissions and restarted the smartphone.
  9. #16
    ehehe nice !
    Nubia Z7MAX
  10. Il seguente Utente ha ringraziato PaoloW8 per il post:
  11. #17
    Sep 2015
    How about battery life?
  12. #18
    link and changelog alpha2 in first page
    Nubia Z7MAX
  13. #19
    Quote Originariamente inviato da Pstelios Visualizza il messaggio
    like cm12.1
    Nubia Z7MAX
  14. #20
    Sep 2015
    thanks a lot
