Skye1337
hello, i have a problem with my smartphone, when i used it for the first time phone go on factory mode, i try wipe emmc but this option didn't work. I try to go in recovery mode but i can't move because up/down didn't work. Then the only way for fix it is SP flash tool, i have find the correct ROM ( on needrom forum) but i can't flash it because when i put USB cable on smartphone and connect on PC it start automatically, and flash tool didn't work if the phone is power on, so what i can do? I can resolve this problemi if i will buy a new motherboard compatibly with this iPhone 6s clone? Thanks.
