把V1 ROM里面的plugin文件夹内容替换到v2 ROM,能解决短信无法接收的问题
替换plugin,replace plugin
IL V1, V2 sulla Base del Rom in sostituzione del Rom, può risolvere il problema non può ricevere SMS.
Ultima modifica di thishj; 20-08-15 alle 23:42
ROM V1 inside the plugin to replace the ROM V2, can solve the problem of SMS can not receive
Ultima modifica di thishj; 20-08-15 alle 23:40
你是直接替换到系统了吗?有没有改权限?还有改权限后重启了没?还是说你是替换到ROM,然后重新刷机。替 换system下的plugin,要删除原来的内容。如果直接替换到系统,要修改权限并重启系 统。
Do you have a direct replacement to the system? Is there a change to the authority? Still have to restart after the change? Or that you are replacing the ROM, and then the brush machine. To replace the plugin system, to delete the original content. If you replace the system directly, you need to modify the permissions and restart the system.
I have V2,i took plugin from V1 and went into revovery. I replaced ithe folder plugin in recovery with system mounted as rw. Then i rebooted a couple of times. I restarted and the system was very laggy and slow when opening applications. And I could not receive sms.
Then I did the same to get pluginV2 back and now it works fine, but no sms received.
Ho la V2. Ho preso la plugin della V1 e sono andato in recovery e mounted system come rw. Ho cambiato plugin folder e reboot. Il systema e diventato lentissimo e non ricevevo sms. Ho fatto il cambii indietro e ora la rom va bene pero non ricevo sms
Edit: i re-did it making sure the permissions for v1 were the same as v2 and same result. Apps take long time to start.
Ultima modifica di pakidermo5000; 22-08-15 alle 14:50
嗯,是有点问题。我现在这个rom是参考了v2修改的,功能正常,很流畅,如果你有兴趣可以刷下试试,以下 地址:pan.baidu.com/s/1bndjIzH
Beh, è un po 'DI PROBLEMI.Ora Ho questo Rom è un riferimento al V2 di modificare la funzione Molto regolare, normale, SE sei interessato, può lavarsi la prossima PROVA, Al seguente indirizzoan.baidu.com/s/1bndjIzH
Hi,
I cannot download. It says the file is too big and I need to install Baidu cloud. I do not want to do that. Can you upload the file on Mega ? or somewhere else ?
Ciao,
non riesco a scaricarlo, il file é tropo pesante e mi chiede di instalare Baidu cloud. Non voglio instalare Baidu cloud. Puoi mettere il file su Mega o qualche altre servizio?
Grazie.
https://mega.nz/#!5RtzxRRS!sG3q2hP9l...zwLy7F-S81pzgk
Oh, that's what I uploaded to mega.
pakidermo5000 (25-08-15)
@ thishj
Which ROM is this? Marsapa? And which version?
I think it is a modified version (I guess by himself) of Marsapa V2.
Penso che é una versione che lui ha modificato della marsapa V2.
