Pagina 2 di 2 primaprima 12
Visualizzazione dei risultati da 11 a 16 su 16
Jiayu g4c
  1. #11
    il g4c dovrebbe avere il processore mtk 6582....come va il cell? soprattutto il gps?
    Ciao,
    allora, secondo Mobileuncle MTK Tools il sistema e' un MKT6589 con 1G Ram e 4G Rom.
    Per quanto riguarda il GPS, va' benino, ho provato piu' configurazioni, ma quella che mi sembra piu' adatta e' il GPS.conf che allego.
    NTP_SERVER=it.pool.ntp.org
    NTP_SERVER=0.it.pool.ntp.org
    NTP_SERVER=1.it.pool.ntp.org
    NTP_SERVER=2.it.pool.ntp.org
    NTP_SERVER=3.it.pool.ntp.org
    NTP_SERVER=0.europe.pool.ntp.org
    NTP_SERVER=1.europe.pool.ntp.org
    NTP_SERVER=2.europe.pool.ntp.org
    NTP_SERVER=3.europe.pool.ntp.org
    NTP_SERVER=time.gpsonextra.net
    NTP_SERVER=asia.pool.ntp.org
    NTP_SERVER=north-america.pool.ntp.org
    XTRA_SERVER_1=http://xtra1.gpsonextra.net/xtra.bin
    XTRA_SERVER_2=http://xtra2.gpsonextra.net/xtra.bin
    XTRA_SERVER_3=http://xtra3.gpsonextra.net/xtra.bin
    # DEBUG LEVELS: 0 - none, 1 - Error, 2 - Warning, 3 - Info
    # 4 - Debug, 5 - Verbose
    DEBUG_LEVEL =0
    # Intermediate position report, 1=enable, 0=disable
    INTERMEDIATE_POS=1
    # Accuracy threshold for intermediate positions
    # less accurate positions are ignored, 0 for passing all positions
    ACCURACY_THRES=5000
    ### THIS IS QUALITY OF SERVICE INFORMATION FOR ###
    ### PROCESSING THE GPS DATA. MOST SHOULD BE ###
    ### SELF-EXPLANATORY. GPS DATA OUTSIDE THE ###
    ### ACCURACY AND THRESHOLD RANGE WILL NOT BE ###
    ### USED WHEN POSITIONING DATA. ###
    QOS_ACCURACY=50
    QOS_TIME_OUT_AGPS=80
    QOS_TIME_OUT_STANDALONE=90
    QosHorizontalThreshold=1000
    QosVerticalThreshold=500
    ### THESE VARIABLES RELATE TO AGPS. IT SAYS TO ###
    ### USE AGPS. THIS WILL NOT BE USED IF YOUR ###
    ### ROM HAS AGPS DISABLED IN THE CODE. ###
    ### THE SERVER IP IS FOR AN INTERNAL IP FOR ###
    ### ACCESSING THE AGPS DAEMONS DATA WHEN IT ###
    ### IS OPERATIONAL. ###
    AssistMethodType=1
    AgpsUse=1
    AgpsServerType=1
    AgpsServerIp=3232235555
    AgpsMtConf=0
    AgpsMtResponseType=1
    # Report supl ref location as position, 1=enable, 0=disable
    REPORT_POSITION_USE_SUPL_REFLOC=1
    # Wiper (wifi positioning), 1=enable, 0=disable
    ENABLE_WIPER=1
    ##### AGPS server settings #####
    # FOR SUPL SUPPORT, set the following
    SUPL_HOST=supl.google.com
    SUPL_PORT=7276
    SUPL_NO_SECURE_PORT=3425
    SUPL_SECURE_PORT=7275
    SUPL_TLS_HOST=FQDN
    SUPL_TLS_CERT=/etc/SuplRootCert
    # FOR C2K PDE SUPPORT, set the following
    C2K_HOST=c2k.pde.com
    C2K_PORT=1234
    CURRENT_CARRIER=common
    DEFAULT_AGPS_ENABLE=TRUE
    DEFAULT_SSL_ENABLE=FALSE
    # TRUE for "User Plane", FALSE for "Control Plane"
    DEFAULT_USER_PLANE=TRUE
  4. #13
    Ringraziato 55 volte in 45 Posts
    vorrei prendere il g4c mi sapete dire se conviene oppure no? lo prenderei dallo store italiano
    This is my account
    My Smartphone
    Vernee Thor, Meizu M2,Xiaomi Redmi 2 Pro, Bq E5 HD Ubuntu , Microsoft Lumia 640 LTE , Jolla Jolla (phone) 16 gb, Motorola Moto G 16 gb: Stock Sony Xperia Play, Archos 45 Titanium , Lg L3
  5. #14
    Banned
    Aug 2013
    Ringraziato 145 volte in 115 Posts
    Quote Originariamente inviato da haterz12 Visualizza il messaggio
    E' un buon telefono... io ne ho ordinato uno per mio cugino da *******... dovrebbe arrivare la prossima settimana..
  6. #15
    Banned
    Aug 2013
    Quote Originariamente inviato da intruderb Visualizza il messaggio
    Ciao,
    Fai un test con Antutu benchmark e vedi che punteggio ottieni
  7. #16
    Androidiano VIP L'avatar di LamaSaldaSprone
    Aug 2013
    佳域 G4, G4S
    Ringraziato 187 volte in 172 Posts
    Oddio, messa così sembrerebbe un basic.
    Se fosse un turbo dovrebbe riportare MT6589T, verifica bene.
    E guarda anche i valori di CPU Frequency.
    Se fosse un advanced dovrebbe inoltre avere più memoria.
    Comunque si, prova con antutu, se stai sui 12-13K è un basic.
    Edit:
    Cercando alcune screenshot sembra che mobileuncle tool non riporti sempre la T finale (ma magari vecchie versioni non erano aggiornate per cogliere la differenza)
    Comunque verifica i valori della voce CPU Frequency.
    Dove lo hai preso?
    Ultima modifica di LamaSaldaSprone; 21-04-14 alle 00:23
    Xiaomi | Mi 5S | MIUI by xiaomi.eu 8.5 | Stabile 8.5.2.0(MAGCNED)
    Xiaomi | Redmi Note 2 Prime | MIUI 8.3 by xiaomi.eu 7.5.25 | Beta
    JiaYu G4S | G4S-20141022-222444佳域
    JiaYu G4 | G4H-20131021-172551佳域
