Ciao,
volevo segnalare il seguente task manager che trovo veramente rivoluzionario:
SystemPanel v1.0.b6 Application for Android | Tools
Ha veramente tantissime funzioni ma, quella che trovo più interessante, è l'help in linea :-) dove si legge:
The OS itself automatically removes programs from memory as memory is needed. The OS may also preload application into memory witch it thinks might soon be needed.
Having lots of available empty memory is not a good thing. It takes the same amount of power to hold "nothing" in memory as it does to hold actual.
So, like every other operating system in use today, android does its best to keep as much important/likely-to-be-used information in memory as possible.
As such, using the task manager feature of SystemPanel to constantly clear memory by killing all apps is strongly NOT RECOMMENDED. This also applies to any other task killer/management program.
Ciao
