Utente del giorno: xPissio con ben 10 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: DreamReaper con ben 50 Thanks ricevuti negli ultimi sette giorni
Utente del mese: complicazio con ben 182 Thanks ricevuti nell'ultimo mese
Problema compilazione Launcher.apk
    Ciao a tutti ragazzi,
    sto cercando di ricompilare Launcher.apk usando APKmultitool.
    Il framework Ŕ caricato correttamente ma ricevo questo messaggio e non riesco a capire che diavolo succede.
    COme posso risolvere?da cosa dipende? ovviamente il log Ŕ molto pi¨ lungo ma volevo solo capire come muovermi
    |03/11/2012 -- 22:23:48,31|
    java version "1.6.0_27"
    Java(TM) SE Runtime Environment (build 1.6.0_27-b07)
    Java HotSpot(TM) 64-Bit Server VM (build 20.2-b06, mixed mode)
    W: Could not find sources
    I: Checking whether resources has changed...
    I: Building resources...
    D:\android\APK\other\..\projects\Launcher.apk\res\ values\strings.xml:1: error: Error parsing XML: XML or text declaration not at start of entity
    D:\android\APK\other\..\projects\Launcher.apk\res\ values\public.xml:453: error: Public symbol string/agree declared here is not defined.
    D:\android\APK\other\..\projects\Launcher.apk\res\ values\public.xml:431: error: Public symbol string/app_name declared here is not defined.
    D:\android\APK\other\..\projects\Launcher.apk\res\ values\public.xml:338: error: Public symbol string/apps_search_activity declared here is not defined.
    D:\android\APK\other\..\projects\Launcher.apk\res\ values\public.xml:405: error: Public symbol string/apr declared here is not defined.
    D:\android\APK\other\..\projects\Launcher.apk\res\ values\public.xml:409: error: Public symbol string/aug declared here is not defined.
    D:\android\APK\other\..\projects\Launcher.apk\res\ values\public.xml:414: error: Public symbol string/bookmark_widget declared here is not defined.
    D:\android\APK\other\..\projects\Launcher.apk\res\ values\public.xml:337: error: Public symbol string/browser_search_component declared here is not defined.
    D:\android\APK\other\..\projects\Launcher.apk\res\ values\public.xml:399: error: Public symbol string/calendar_widget declared here is not defined.
    D:\android\APK\other\..\projects\Launcher.apk\res\ values\public.xml:450: error: Public symbol string/clear_shortcuts declared here is not defined.
    D:\android\APK\other\..\projects\Launcher.apk\res\ values\public.xml:452: error: Public symbol string/clear_shortcuts_prompt declared here is not defined.
    D:\android\APK\other\..\projects\Launcher.apk\res\ values\public.xml:451: error: Public symbol string/clear_shortcuts_summary declared here is not defined.
    D:\android\APK\other\..\projects\Launcher.apk\res\ values\public.xml:393: error: Public symbol string/control_middle_text declared here is not defined.
    D:\android\APK\other\..\projects\Launcher.apk\res\ values\public.xml:440: error: Public symbol string/corpus_description_apps declared here is not defined.
    D:\android\APK\other\..\projects\Launcher.apk\res\ values\public.xml:443: error: Public symbol string/corpus_description_apps_market declared here is not defined.
    D:\android\APK\other\..\projects\Launcher.apk\res\ values\public.xml:438: error: Public symbol string/corpus_description_web declared here is not defined.
    D:\android\APK\other\..\projects\Launcher.apk\res\ values\public.xml:441: error: Public symbol string/corpus_hint_apps declared here is not defined.
