[App]Strumenti Gps
    Aug 2013
    [App]Strumenti Gps
    Descrizione:
    Do you need a professional app to accompany you during your navigation, then try this App!
    ++If there are any problems with the application, tell me what's wrong so that I can fix the problem!
    "Navigation tools' app has 7 screens full of information:
    1. Satellite positions in the sky (skyview), shown on a radar(including additional information).
    2. Your current speed, battery level and battery temperature shown on a speedometer.
    3. Your current altitude shown on as text, on a graph,and on a altitude chart.
    4. A simple compass showing you your direction (Additional: Pitch and Roll).
    5. Artificial Horizon
    6. Inclinometer showing you the pitch and the roll of your car.
    7. Proximity Alert (It alerts you when you are near a point of interest), Place Finder (A simple search engine for the Map), Place surfer (Showing you important information about a place picked by you).
    New Tools will be added as soon as possible.
    Scaricare:
    Gratis: https://play.google.com/store/apps/d...avigationTools
    Pagato: https://play.google.com/store/apps/d...ationTools.Pro
    Immagini allegate
