Utente del giorno: Stahl con ben 17 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: Stahl con ben 50 Thanks ricevuti negli ultimi sette giorni
Utente del mese: complicazio con ben 200 Thanks ricevuti nell'ultimo mese
Pagina 2 di 2 primaprima 12
Problema con viber
  1. #11
    thanks a lot for your responds.
    I'm using a samsung w (i8150) 2.3.6.
    I hope my BT headset will be supported very soon, if I can I will try another BT for compatibility.
    Sorry for my bad English...
    Androidiano L'avatar di Viber
    Ringraziato 28 volte in 28 Posts
    Quote Originariamente inviato da Luponr3 Visualizza il messaggio
    Your English is excellent - you shouldn't worry about it
    Well,
    Please note that Viber does not officially support Samsung W i8150 yet, and that may be the reason for the problems you are experiencing with your Bluetooth. Here is the full list of officially supported devices: Is your Android compatible with Viber (system requirements)? | Viber Support
    We are continuously working to adapt Viber to more and more devices, and we hope to attend to the problems with your device soon. We apologize for the inconvenience.
  4. Il seguente Utente ha ringraziato Viber per il post:
    Luponr3 (16-12-11)
  5. #13
    Good, I hope will be supported very soon.
    tanks for the great job and support.
  6. #14
    E 'il mio piacere!
    If you have any other questions/suggestions/technical problems - feel free to let me know, of course.
  7. #15
    LocalitÓ
    Caserta
    Galaxy S2 / Mi2S 32G / N5 32G
    Ringraziato 65 volte in 39 Posts
    Hi I use viber with my Samsung Galaxy S2 (I9100) and I have as BT Headset "Nokia BH104" and when I call with viber I can't use my BT headset. Is incompatible with viber? Did you tested it? Thanks!!!
  8. #16
    Androidiano VIP L'avatar di fratoff91
    Nov 2010
    Ringraziato 677 volte in 373 Posts
    Che ci fa questo thread nella sezione del galaxy w???
    Inviato dal mio GT-I8150 con Tapatalk 2
  9. #17
    Androidiano VIP L'avatar di pasquale9620
    LocalitÓ
    Caserta
    Galaxy W
    Ringraziato 199 volte in 171 Posts
    Quote Originariamente inviato da fratoff91 Visualizza il messaggio
    LOL
    Premi "Thanks"se ti sono stato d'aiuto!!
    ROM Galaxy W:
    Black Notes -Last Page:
    http://www.androidiani.com/forum/sam...last-page.html
    RebelROM 3.0.6 Milestone 2: http://www.androidiani.com/forum/sam...stone-2-a.html
    Bagux Project ROM v1.4
    : http://www.androidiani.com/forum/sam...om-v1-2-a.html
    ANDROIDIANO VIP
  10. #18
    Quote Originariamente inviato da simpatiacaserta Visualizza il messaggio
    Hi,
    Viber does support most Bluetooth/headset devices in general. However, some are not supported, due to the restrictions within the phone itself (sometimes certain iPhone/Android features or external devices do not function smoothly with 3rd-party applications). We have fixed Viber in our lastest versions so MOST of the BT/headset devices can work, but unfortunately some others are just not fully compatible yet, and we're continuously working to adapt the app to more and more BT and headset devices
    For more info, please contact our support team at Viber Support and Knowledge Base
