Android Scripting Environment (ASE)
Google ha rilasciato l'Android Scripting Environment (ASE), liberando quindi la potenza di LUA e Python anche sull'androide!!!
Questa la descrizione presa dal blog Google:
The Android Scripting Environment (ASE) brings scripting languages to Android by allowing you to edit and execute scripts and interactive interpreters directly on the Android device. These scripts have access to many of the APIs available to full-fledged Android applications, but with a greatly simplified interface that makes it easy to:
* Handle intents
* Start activities
* Make phone calls
* Send text messages
* Scan bar codes
* Poll location and sensor data
* Use text-to-speech (TTS)
* And more
Scripts can be run interactively in a terminal, started as a long running service, or started via Locale. Python, Lua and BeanShell are currently supported, and we're planning to add Ruby and JavaScript support, as well.
La cosa e' ghiottissima!!!!
Forse vale la pena una news in homepage? :D
Questo il link ufficiale alla news
