Non mi esegue il root non capisco perché mi sa che fa errore verso la fine guardate:
codice:[*][*] Megatron: LG Optimus 3D/Thrill Root Exploit (Windows version)[*] by Dan Rosenberg (@djrbliss)[*][*] Before continuing, ensure USB debugging is enabled, that you[*] have the latest LG drivers installed, and that your phone[*] is connected via USB.[*][*] Press enter to root your phone... Premere un tasto per continuare . . .[*][*] Waiting for device... * daemon not running. starting it now * * daemon started successfully *[*] Device found.[*] Deploying payload... 2306 KB/s (564396 bytes in 0.239s) pkg: /data/local/tmp/evil.apk Success[*] Owning phone...[*] Rebooting device...[*] Waiting for phone to reboot.[*] Writing to block device... 422 KB/s (4322 bytes in 0.010s)[*] Searching block device for string, this may take a minute. [1] Bus error /data/local/block[*] Pushing root tools to device... 1559 KB/s (22364 bytes in 0.014s) 4118 KB/s (843503 bytes in 0.200s)[*] Rebooting device again...[*] Waiting for phone to reboot.[*] Getting root... cp: cannot create '/system/app/Superuser.apk': Read-only file system Unable to chmod /system/app/Superuser.apk: No such file or directory[*] Cleaning up... cp: cannot create '/system/bin/run-as': Read-only file system Unable to chmod /system/bin/run-as: Read-only file system Unable to chmod /system/bin/run-as: Read-only file system Success[*] Rebooting... error: more than one device and emulator[*] Exploit complete![*] Press any key to exit. Premere un tasto per continuare . . .
LinkBack URL
About LinkBacks
Rispondi quotando
