Allora, finalmente dopo aver girovagato come un matto per la rete, ho trovato questa guida CHE FUNZIONA!! (è in inglese ma facilmente traducibile con google traslate). Dice d'installare un programmino in cinese (ho già controllato bene che sia privo di virus), si seguono le istruzioni facilissime e in men che non si dica si effettua il root!
Il mio cell è un P760 e non P710 come avevo erroneamente scritto... cmq vale per i modelli P760,P765,P768,P769
[TUTORIAL] ROOT LG Optimus L9 - EASY! (P760,P765,P768,P769) (aggiornata al 10th September 2013, 07:59 PM)
Hello guys, since all of the tutorials I have seen on here are all complicated I decided to post the easiest method around. You don't even need to use any command prompt for this. The only problem is that this is chinese language, so you have to click the exact buttons.
1. Download this file:
www.mgyun. com/vroot
2. Install the software, using the installation buttons as you would on any other windows installation.
3. When you have installed it, you will see a green button, press it. Then connect your phone (JellyBean update would be best, i havent tried with ICS)
4. When the phone is connected the software will recognise the phone and the green button will show "ROOT", click on it.
5. The phone is going to be rooted in some seconds and the process is finished when it will show a tick on the software.
6. The phone will reboot.
7. When it is rebooted, go to google play and download super su.
8. Open super su and it will ask you to update the binaries, and you must click on update, and then normal.
9. A window in chinese will pop up on the phone, this is the screen that allows you to give root permissions to any app. You must click the button on the right.
10. You are done! Root process is complete!
11. This is the most important step. Leave a thanks! If you liked the tutorial, please show it to me!
Per dare a Cesare quel che è di Cesare, ringrazio l'autore aristide1997 e il forum dove ho preso le info:
[TUTORIAL] ROOT LG Optimus L9 - EASY! (P760,P765,P768,P769) - xda-developers
Ciao
Ps. non entrate in paranoia per il cinese, i tasti incomprensibili da premere sono 2 (di cui uno gigante in verde sul pc e l'altro sul cell che è quello di destra) e poi perché non vi cambierà nulla ne sul cell ne sul pc!
