Utente del giorno: 9mm con ben 3 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: kotix con ben 9 Thanks ricevuti negli ultimi sette giorni
Utente del mese: bluemask con ben 49 Thanks ricevuti nell'ultimo mese
Pagina 3 di 14 primaprima 1234513 ... ultimoultimo
Visualizzazione dei risultati da 21 a 30 su 139
Mediacom Pad phone Duo g530 root and cwm 6.0.3.0
  1. #21
    ecco ... questa e con l sd card 1
    Microsoft Windows XP [Versione 5.1.2600]
    (C) Copyright 1985-2001 Microsoft Corp.
    C:\Documents and Settings\Edo>cd C:\root_g530\
    C:\root_g530>adb push recovery_pad_g530.img/storage/sdcard1/
    Android Debug Bridge version 1.0.29
    -d - directs command to the only connected USB devic
    e
    returns an error if more than one USB device is
    present.
    -e - directs command to the only running emulator.
    returns an error if more than one emulator is r
    unning.
    -s <serial number> - directs command to the USB device or emulator w
    ith
    the given serial number. Overrides ANDROID_SERI
    AL
    environment variable.
    -p <product name or path> - simple product name like 'sooner', or
    a relative/absolute path to a product
    out directory like 'out/target/product/sooner'.
    If -p is not specified, the ANDROID_PRODUCT_OUT
    environment variable is used, which must
    be an absolute path.
    devices - list all connected devices
    connect <host>[:<port>] - connect to a device via TCP/IP
    Port 5555 is used by default if no port number
    is specified.
    disconnect [<host>[:<port>]] - disconnect from a TCP/IP device.
    is specified.
    Using this command with no additional arguments
    will disconnect from all connected TCP/IP devic
    es.
    device commands:
    adb push <local> <remote> - copy file/dir to device
    adb pull <remote> [<local>] - copy file/dir from device
    adb sync [ <directory> ] - copy host->device only if changed
    (-l means list but don't copy)
    (see 'adb help all')
    adb shell - run remote shell interactively
    adb shell <command> - run remote shell command
    adb emu <command> - run emulator console command
    adb logcat [ <filter-spec> ] - View device log
    adb forward <local> <remote> - forward socket connections
    forward specs are one of:
    tcp:<port>
    localabstract:<unix domain socket name>
    localreserved:<unix domain socket name>
    localfilesystem:<unix domain socket name>
    dev:<character device name>
    jdwp:<process pid> (remote only)
    adb jdwp - list PIDs of processes hosting a JDWP transport
    adb install [-l] [-r] [-s] <file> - push this package file to the device and i
    nstall it
    ('-l' means forward-lock the app)
    ('-r' means reinstall the app, keeping its data
    ('-s' means install on SD card instead of inter
    nal storage)
    adb uninstall [-k] <package> - remove this app package from the device
    ('-k' means keep the data and cache directories
    adb bugreport - return all information from the device
    that should be included in a bug report.
    adb backup [-f <file>] [-apk|-noapk] [-shared|-noshared] [-all] [-system|-nosy
    stem] [<packages...>]
    - write an archive of the device's data to <file>
    If no -f option is supplied then the data is wr
    itten
    to "backup.ab" in the current directory.
    (-apk|-noapk enable/disable backup of the .apks
    themselves
    in the archive; the default is noapk.)
    (-shared|-noshared enable/disable backup of the
    device's
    shared storage / SD card contents; the defau
    lt is noshared.)
    (-all means to back up all installed applicatio
    ns)
    (-system|-nosystem toggles whether -all automat
    ically includes
    system applications; the default is to inclu
    de system apps)
    (<packages...> is the list of applications to b
    e backed up. If
    the -all or -shared flags are passed, then t
    he package
    list is optional. Applications explicitly g
    iven on the
    command line will be included even if -nosys
    tem would
    ordinarily cause them to be omitted.)
    adb restore <file> - restore device contents from the <file> backup
    archive
    adb help - show this help message
    adb version - show version num
    scripting:
    adb wait-for-device - block until device is online
    adb start-server - ensure that there is a server running
    adb kill-server - kill the server if it is running
    adb get-state - prints: offline | bootloader | device
    adb get-serialno - prints: <serial-number>
    adb status-window - continuously print device status for a specifie
    d device
    adb remount - remounts the /system partition on the device re
    ad-write
    adb reboot [bootloader|recovery] - reboots the device, optionally into the boo
    tloader or recovery program
    adb reboot-bootloader - reboots the device into the bootloader
    adb root - restarts the adbd daemon with root permissions
    adb usb - restarts the adbd daemon listening on USB
    adb tcpip <port> - restarts the adbd daemon listening on TCP on th
    e specified port
    networking:
    adb ppp <tty> [parameters] - Run PPP over USB.
    Note: you should not automatically start a PPP connection.
    <tty> refers to the tty for PPP stream. Eg. dev:/dev/omap_csmi_tty1
    [parameters] - Eg. defaultroute debug dump local notty usepeerdns
    adb sync notes: adb sync [ <directory> ]
    <localdir> can be interpreted in several ways:
    - If <directory> is not specified, both /system and /data partitions will be u
    pdated.
    - If it is "system" or "data", only the corresponding partition
    is updated.
    environmental variables:
    ADB_TRACE - Print debug information. A comma separated list
    of the following values
    1 or all, adb, sockets, packets, rwx, usb, sync
    , sysdeps, transport, jdwp
    ANDROID_SERIAL - The serial number to connect to. -s takes prior
    ity over this if given.
    ANDROID_LOG_TAGS - When used with the logcat option, only these de
    bug tags are printed.
    C:\root_g530>adb shell
    shell@android:/ $ su
    su
    root@android:/ # dd if=/storage/sdcard1/recovery_pad_g530.img of=/dev/recovery
    _pad_g530.img of=/dev/recovery <
    /storage/sdcard1/recovery_pad_g530.img: cannot open for read: No such file or di
    rectory
    1|root@android:/ # sync
    sync
    sync
    sync
    root@android:/ # reboot recovery
    reboot recovery
    C:\root_g530>
    Senior Droid L'avatar di effeci2
    Sicilia
    Wiko Rainbow Jam -Vodafone 875
    Ringraziato 232 volte in 153 Posts
    Prova con
    adb push nomefile.img /cartella/sottocartella/nomefile.img
    cioè metti il nome del file della recovery anche alla fine del comando
    Wiko Rainbow Jam MTK6580 Lollipop 5.1 - Wiko Iggy MTK6572 JB 4.2.2 - Mediacom Smartpad 722Mobile MTK6582 JB 4.2.2 - Mediacom Smartpad 706 Allwinner JB 4.1.1 by effeci2 - Mediacom Smartpad 720 e 722 Amlogic ICS 4.0.4 - Dicra Tab208 CyanogenMod 10 JB 4.1.1
  4. #23
    provato .. non capisco il problema di tutto ciò..
    C:\root_g530>adb push recovery_pad_g530/storage/sdcard0/recovery_pad_g530.img
    e
    present.
    unning.
    ith
    AL
    is specified.
    is specified.
    es.
    device commands:
    tcp:<port>
    nstall it
    nal storage)
    itten
    themselves
    device's
    lt is noshared.)
    ns)
    ically includes
    de system apps)
    e backed up. If
    he package
    iven on the
    tem would
    archive
    scripting:
    d device
    ad-write
    e specified port
    networking:
    pdated.
    is updated.
    su
    root@android:/ # dd if=/storage/sdcard0/recovery_pad_g530.img of=/dev/recovery
    /storage/sdcard0/recovery_pad_g530.img: cannot open for read: No such file or di
    rectory
    1|root@android:/ #
  5. #24
    Senior Droid L'avatar di vocoderism
    Sep 2013
    Ringraziato 140 volte in 97 Posts
    Quote Originariamente inviato da Giorgio1325 Visualizza il messaggio
    e
    present.
    unning.
    ith
    AL
    is specified.
    is specified.
    es.
    device commands:
    tcp:<port>
    nstall it
    nal storage)
    itten
    themselves
    device's
    lt is noshared.)
    ns)
    ically includes
    de system apps)
    e backed up. If
    he package
    iven on the
    tem would
    archive
    scripting:
    d device
    ad-write
    e specified port
    networking:
    pdated.
    is updated.
    su
    rectory
    1|root@android:/ #
    Sbagli comando lanci
    Invece devi lanciare
    adb push recovery_pad_g530.img /storage/sdcard0/
    Poi fai il resto
  6. #25
    No non ho sbagliato .. Ho provato con il comando che mi aveva consigliato effeci2
  7. #26
    Sep 2013
    Copia il comando come te l ho inviato ora e poi fai il resto
  8. #27
    Sicilia
    Giorgio
    Dal pc leggo meglio....sbagli perche' scrivi tutto attaccato.
    dopo _g530 ci deve essere uno spazio prima di /storage/sdcard0/
    adb push recovery_pad_g530 /storage/sdcard0/recovery_pad_g530.img
    e
    sono equivalenti come comandi, il primo e' piu' prolisso...
  9. Il seguente Utente ha ringraziato effeci2 per il post:
    Giorgio1325 (19-09-13)
  10. #28
    Sep 2013
    Quote Originariamente inviato da effeci2 Visualizza il messaggio
    Giorgio
    e
    Corretto
    Dopo g530 metti. img
    Qnd
  11. Il seguente Utente ha ringraziato vocoderism per il post:
  12. #29
    risolto tutto ci sono riuscito ... grazie a tutti per il tempo che mi avete impiegato
  13. #30
    adesso ci vuole una bella rom .. qualcuno sa se per caso ce ne in giro??
