Pagina 1 di 4 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 35
Firmware aggiornamento 4.5.4.1A
    Senior Droid L'avatar di tafazzi87
    Ringraziato 39 volte in 35 Posts
    è uscito il nuovo aaggiornamento ufficiale per firmware globale
    siamo arrivati alla 4.5.4.1 A
    qui trovate il link per il download Flyme OS????-?? 2
    Changelog:
    System
    Fix: Some problems caused by machine restarts.
    Fix: Some compatibility issues Google office suite.
    FIX: unlock the phone, even now the state of the desktop display to add a floating widget of the problem.
    Fix: call custom reply interface hang up, press the power button does not lock the screen problem.
    Fix: Click on the notification bar in the middle position, even now drop down the status bar at the top of the interface card problem.
    Communication
    Optimization: Optimize performance WI-FI.
    Fix: Even now call a silent problem.
    Fix: Even now unable incoming phone problem.
    Fix: make Internet phone calls is now even unusual problems.
    FIX: contact list does not appear even now heading back problems contact number.
    Browser
    Optimization: Part page transition effects screen anyway.
    FIX: Do not display photographs, a browser interface display unusual problems.
    Easy Mode
    Fix: Easy mode receives MMS, after exiting the easy mode, MMS reception failure problems.
    Fix: Easy mode the system language is set to English dial display problems.
    FIX: Contacts list is sorted easy mode without problems arranged in numerical size.
    FIX: When adjusting the ringer volume in simple mode calls, will also play two tones sound problems.
    Voice assistant
    Optimization: Optimization voice assistant adjust the screen brightness effect.
    FIX: Using Voice “Close GPS”, the status bar to open the GPS icon still shows problems.
    Personalization center
    FIX: Topic list into the theme from the local online page add a comment, suggesting that “comments failure” problem.
    Ultima modifica di tafazzi87; 23-11-15 alle 15:46
    Finora posso dire che il bug delle macro e dello spostamento del cursore quando una parola è selezionata non è stato fixato...
    Il WiFi invece sembra più stabile
    se la installo mi cancella i dati?
    Se la aggiorni dalla 4.5.3.2A no
    Quote Originariamente inviato da tafazzi87 Visualizza il messaggio
    si vengo da quella. a voi da problemi titanium backup pro? a me non la mette proprio in home, l'unica opzione che mi da è uninstall. Cmq ancora non me lo segna tra gli upgrade
    No non mi da problemi titanium backup... Cmq scaricala dal sito che ho messo sopra casomai e metti l'update.zip nella memoria principale e fai l'update
  9. #8
    update dall'applicazione aggiornamento?
  10. #9
    Ringraziato 95 volte in 90 Posts
    Impressione o ha meno linea di prima.... Per la prima volta ho visto no service
  11. #10
    Dovrebbe segnalarlo dall'applicazione aggiornamento anche...
