Utente del giorno: Varioflex con ben 2 Thanks ricevuti nelle ultime 24 ore
Pagina 76 di 76 primaprima ... 2666747576
Visualizzazione dei risultati da 751 a 757 su 757
[ROM] Ice 2
  1. #751
    Androidiano VIP L'avatar di Amir.C
    Zuk Z2-Galaxy S3-Acer E310
    Ringraziato 190 volte in 157 Posts
    Quote Originariamente inviato da sharang Visualizza il messaggio
    Hello everyone i am back Sorry i dont find gabber to be active regarding ice 2 rom so i'll be posting new mods here itself !
    This time i modded framework and implemented ICS/JB like task switcher
    Allegato 71509
    But there is one problem ! The task switcher works fine but the recently used app goes to bottom and the least used app comes to top ! It does have 8 recently used apps ! I want someone to add scrollview and fix this problem ! Rest everything works Give it a try
    link : jb-framework-ICS switcher.zip
    Also i found one app in the play store which gives android 4.2 like feel i.e in systemUI.apk
    Allegato 71513Allegato 71514
    The app is known as "Mappz quick settings"..It has both paid and free versions
    Flash the abv framework and do let me know !
    Nice work man! ;D
    1° Device: Oneplus 6: Rom Stock
    2° Device: Zuk Z2: GizRom
    3° Device: Samsung Galaxy S3
    4° Device: Acer Liquid Mini E310
    Baby Droid L'avatar di sharang
    India
    Acer liquid mini & S4
    Can someone implement scroll view in that task switcher ?? I tried but nothing happened :/
  4. #753
    LG G2
    After flashing the rom you can flash the above mentioned zips i.e framework.zip or systemui.zip or settings.zip
    Can I flash all zip mentioned??
  5. #754
    India
    Quote Originariamente inviato da bennynico Visualizza il messaggio
    Yes you can !
  6. #755
    LG G2
    Sorry, but everytime that I flash zips Have I to reboot sistema? or
    Can I flash all zips without reboot?
    Inviato dal mio E310 usando Androidiani App
  7. #756
    Androidiano VIP L'avatar di ErCampa
    Brescia
    xt530, s4, g2, s5, note 3
    Ringraziato 138 volte in 115 Posts
    Come tastiera hai messo questa https://play.google.com/store/apps/d...artkeyboardpro ?
    EDIT: dalle app aggiunte vedo app che costano.. Su questo forum non è consentito. RISCHI BAN!
    Ultima modifica di ErCampa; 14-07-13 alle 19:13
  8. #757
    Mar 2009
    Chiudo in attesa di riscontri.
