[THREAD UFFICIALE][MODDING]Lenovo A750
Lenovo A750
http://www.vivandroid.com/img/lenovo...roid_4.0_1.jpg
Lo smartphone A750 di Lenovo Corporation
http://i1212.photobucket.com/albums/...ovoA750BOX.jpg
http://i1212.photobucket.com/albums/...ovoA750SET.jpg
http://i1212.photobucket.com/albums/...voA750OPEN.jpg
In questo 3d troverete raggruppate tutte le risorse per utilizzare al meglio questo device ed inoltre le personali discussioni e novita' a riguardo aggiornate nel tempo
Spero ovviamente nella vostra collaborazione per il suo arricchimento ed aggiornamento
Caratteristiche tecniche :
Manufacturer Lenovo
First released March 2012
Type Slate smartphone
Dimensions 125.6 mm (4.94 in) H
65.9 mm (2.59 in) W
13.8 mm (0.54 in) D
Weight 159.5 g (5.63 oz)(including battery)
Operating system Android 2.3.6 or 4.0.3
CPU MTK MT6575 1 GHz processor with PowerVR SGX 531 ProGPU
Memory 512 MB RAM
Storage 4 GB NAND
2 GB microSD memory card (SD 2.0 compatible)
microSD slot: supports up to 32 GB
Battery 2000 mAh
Internal rechargeable lithium-ion battery
Data inputs Multi-touch capacitive touchscreen display, 3-axis accelerometer, proximity and ambient light sensors
Display 480 × 800 px, 4.0 in (100 mm), WVGA, TFT LCD capacitive touchscreen
Rear camera 5.0 megapixel with auto focus without LED Flash
Front camera 0.3 MP, fixed focus, front-facing
Connectivity Wi-Fi (802.11 b/g), Bluetooth 2.1+EDR, GSM 850 900 1800 1900 MHz HSPA/WCDMA 900 2100 MHz, GPS
Other Proximity sensor, accelerometer, FM radio, GPS, A-GPS.
Interessante anche il dato sulle emissioni radio che e' regolarmente sotto i parametri di legge:
SAR: Maximum only 0.233w/kg
Link alla pagina Wikipedia :LINK
